FTTC - Vodafone Suresignal IP Problems?
- FTTC - Vodafone Suresignal IP Problems?
Re: FTTC - Vodafone Suresignal IP Problems?
18-12-2014 9:54 AM
Happy
18-12-2014 10:42 AM
This change has been rolled back and nobody should have further issues.
Again apologies for the inconvenience.
18-12-2014 12:37 PM
18-12-2014 1:19 PM
18-12-2014 1:26 PM
18-12-2014 2:22 PM
Quote from: All4One All ports over 9000
not sure that's correct.
18-12-2014 2:52 PM
jim:quote
18-12-2014 2:59 PM
18-12-2014 6:57 PM
18-12-2014 6:59 PM
18-12-2014 7:15 PM
21-12-2014 9:21 AM
Mine has stopped working again
Ian
edit static IP 212.159.xxx.xxx
gateway You are currently connected to gateway ptn-ag02.
ADSL
2nd EDIT : reconnected the ppp session and it now seems to be working
21-12-2014 11:17 AM
23-12-2014 6:24 AM
It was working fine Monday morning over ADSL but is unable to connect since our live switched to fiber.
We currently have a BT Home hub 5, & have tried opening the necessary suresignal ports using port forwarding & enabled vpn port clamping.
No problem connecting with other vpns - ipsec connections work fine as does an SSL vpn. Just the sure signal....
Any ideas? Seems like that port blocking has somehow come back into play?
23-12-2014 1:42 PM
