Cannot play online games
- Re: Cannot play online games
27-10-2015 9:53 AM
Hi all
I recently moved house and got fibre installed. This came with a new router.
In my previous house all steam games would connect and could play online no problem.
Offline games are still fine so I have ruled steam out.
My PC hardware and OS are unchanged (win 10)
Since the new fibre install any steam game which requires a server connection will time out and not connect (eg DayZ)
I have tried:
PC
Logging in/out steam
Creating windows firewall exceptions
Disabling windows firewall
Disabling antivirus
ROUTER
Disabling router firewall
UPNP definately enabled
Portforwarding required ports
Adding PC to DMZ
I have used an online port checker and it's telling me ports are closed, so I'm convinced the router is not doing what it's supposed to, and it is the only real change in the set up.
This new plusnet router is even more basic, with less control than the last one, but moving from copper to fibre and the introduction of the BT modem I'm not sure how compatible the routers are (ie used the old router but couldn't establish a connection)
Does anyone have any suggestions of things to try?
Thank you
Joe
I have tried:
PC
Disabling antivirus
ROUTER
Adding PC to DMZ
Thank you
Joe
Message 1 of 8
(1,506 Views)
7 REPLIES 7
27-10-2015 8:47 PM
A long shot but have you checked your plusnet fire wall, you will need to lo on to your member centre and look under connection settings.
Message 2 of 8
(1,005 Views)
28-10-2015 8:29 AM
Hi Den
Thanks I haven't tried that, and I will see, although pre-move it was ok so I doubt it will solve the problem.
I was disappointed in the ultra-basic gui of the router. I found this googling, which improves things somewhat, but hasn't help solve the issue.
192.168.1.254/expert_user.html More functions and access to the router
Message 3 of 8
(1,005 Views)
28-10-2015 8:49 AM
Ok in the member centre
Broadband firewall - OFF
Safesurf - Unrestricted
Message 4 of 8
(1,005 Views)
01-11-2015 9:43 AM
bump for help
this is really starting to cheese me off and I don't know what else to try
Message 5 of 8
(1,005 Views)
01-11-2015 12:54 PM
what router were you using before the sagemcom one ?
the problem is quite possibly the router not doing what its supposed to, in which case you might be able to use your old router, if your old router was the tg582n then you will need ot get the firmware updated to the fibre version and it will use one of the Ethernet ports to connect to the modem , if you had a home hub v4 or 5 then you should be able to plug that into the modem and type in your username /password in the connection wizard as a pppoe connection and continue using it, if you used a different router then so long as its pppoe capable you should be fine to do something similar with that.
failing that do some research and buy a VDSL2+ router would be my suggestion
Message 6 of 8
(1,005 Views)
01-11-2015 4:28 PM
Wouldn't Surprise me if PN safesurf is the culprit
Message 7 of 8
(1,005 Views)
01-11-2015 4:35 PM
Hi nanotm
thanks for your reply
Before the sagecom one I was using an old belkin modem router I bought an Asus ac56u yesterday to use behind the BT box which has helped, for example DayZ now works as do some other games. Unfortunately not everything is working. Fishing Planet is one that just fails to connect, it's not the end of the world but it's irritating.
I'll probably try the steam game specific forum as I have narrowed it down to a few things, I'm satisfied it's not ISP related and I'm no longer using ISP hardware.
Cheers!
@ rongtw Safesurf is disabled
Cheers!
Message 8 of 8
(1,005 Views)
