Can't connect to some sites.
- Can't connect to some sites.
31-10-2015 9:33 AM
Problem started around 11pm 29/10. Although I can connect to some sites normally, others take ages to load whilst some just time out. Carried out all the troubleshooting checks on both my Billion 8800NL router and the PlusNet/Openreach equipment, both the same. PC is connected to the router by cable and the wireless connection on my mobile is working but has the same problem. I have raised a support ticket but in the meantime I wondered if anyone is experiencing similar problems or has any brilliant ideas as to what the problem may be. Thanks.
Len
Len
Message 1 of 4
(646 Views)
3 REPLIES 3
Re: Can't connect to some sites.
31-10-2015 9:40 AM
Message 2 of 4
(428 Views)
31-10-2015 10:47 AM
Matthew,
Here's a traceroute for a site I can't reach:
C:\WINDOWS\system32>tracert pocketgpsworld.com
Tracing route to pocketgpsworld.com [95.142.159.205]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 34 ms 34 ms 34 ms lo0.10.Central10.pcl-bng04.plus.net [195.166.130.177]
3 35 ms 34 ms 34 ms irb.10.PCL-CR02.plus.net [84.93.249.82]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 *
and one for I site I can:
C:\WINDOWS\system32>tracert forums.evga.com
Tracing route to a1195.g1.akamai.net [212.56.73.143]
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
3 35 ms 34 ms 34 ms irb.10.PCL-CR01.plus.net [84.93.249.81]
4 35 ms 34 ms 34 ms cache.akamai.com [212.56.73.143]
Trace complete.
Thanks.
Len
8 *
Trace complete.
Thanks.
Len
Message 3 of 4
(428 Views)
31-10-2015 11:18 AM
Matthew,
A further one to a site I can get to eventually:
C:\WINDOWS\system32>tracert nforcershq.com
Tracing route to nforcershq.com [108.160.148.58]
4 36 ms 35 ms 35 ms 195.99.126.98
5 35 ms 35 ms 35 ms 109.159.249.149
6 35 ms 35 ms 35 ms 62.6.201.167
7 35 ms 34 ms 35 ms 213.137.183.38
8 128 ms 120 ms 119 ms 166.49.208.121
9 * * * Request timed out.
10 122 ms 121 ms 121 ms blt1-ar3-xe-0-0-0-0.us.twtelecom.net [66.192.245.134]
11 122 ms 122 ms 122 ms 199.227.4.198
12 114 ms 114 ms 113 ms 144.202.254.42
13 114 ms 114 ms 114 ms 144-202-238-253.baltimoretechnologypark.com [144.202.238.253]
14 114 ms 114 ms 114 ms 144.202.227.20
15 114 ms 114 ms 114 ms 108.160.148.58
Trace complete.
Len
Trace complete.
Len
Message 4 of 4
(428 Views)
