Budget Wireless Router
willas00
Since having my Fibre broadband installed ive had nothing but problems with the wireless dropping out all the time
Can anyone recommend any decent wireless routers with a maximum price tag of around £80.
I rely on the wireless a lot so wireless is important to me
27 REPLIES 27
30FTTC06
Fixes: 4
Re: Budget Wireless Router
Yeah buy a D-Link Dir-615 and put dd-wrt on it, max cost from ebay should be £10, I run 2 on my network, rev D2 and D4.
As a side note, I run a local cache per AP as follows.
tijara33
Fixes: 6
You will be able to purchase the excellent Asus RT-N56U for £70.41 from Amazon. I've been using mine for over 2 years & it is brilliant. Smiley
http://www.amazon.co.uk/Asus-RT-N56U-Wireless-Hardware-streaming/dp/B004TPWRSK
Randall8686
Yes the Asus ! I run an Asus RT-AC68U, however have always recommended the Asus routers to people and everyone has always been more than impressed. You will not get issues on your wireless unless the problem is caused by an external source.
HairyMcbiker
All Star
Fixes: 21
TP-Link TD-W9980 £70 from Kikatek with free delivery.
Both ADSL & fibre so future proof. 2.4 & 5Ghz wifi.
willas00
Because of the way fibre works would this ASUS device replace the Plusnet box? I'd imagine the BT Openzone box is vital
30FTTC06
Fixes: 4
AC68U Is £150!
Your best option is...
"Built-in VDSL2 Modem for Fibre Broadband up to 100Mbps!"
http://www.broadbandbuyer.co.uk/products/17047-tp-link-td-w9980/
A regular visitor to plusnet has a review here http://www.kitz.co.uk/routers/tplink_TD-W9980_review.htm
Yes it will do away with the bt gear.
tijara33
Fixes: 6
Why would I want to do away with the BT modem?
30FTTC06
Fixes: 4
I was answering a question from willas00 tijara33.
Quote from: willas00
You don't unless you want to use just a single box and be eco-freindly tijara33 Smiley
WWWombat
That TP-link having limited VDSL2 diagnostics would kill the idea for me.
The Kitz forum has a list of combined router-modems that do away with the Openreach modem. I think people on the list seem to like one of the Zyxel models...
http://forum.kitz.co.uk/index.php?topic=14436.0
I have been running two separate boxes, and use the TP-Link WDR3600 as a router. Right now, I'm very pleased it does simultaneous 5GHz and 2.4GHz wifi.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
willas00
I'm not bothered about doing away with the Openreach box just the Plusnet router.
Both are on different sides of the room so just looking to replace the Plusnet fibre router
30FTTC06
Fixes: 4
In thst case...... Asus RT-N56U for £70.41
zpeterk
How about an Airport Extreme, can be purchased cheap on auction sites and fast wifi
HairyMcbiker
All Star
Fixes: 21
The TP link doesn't need the BT modem at all.
The wan diag is basic, but more than you get from the PN box, without hacking the BT modem.
DSL
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/B/L/M
Upstream Downstream
Current Rate (Kbps) 20000 65358
Max Rate (Kbps) 26768 75796
SNR Margin (dB) 9.9 5.9
Line Attenuation (dB) 13.2 13.7
Errors (Pkts) 0 0
Is the status report on the front page.
petecov44
I have plenty of AP's that will do PPPoE you can have one for nothing if I can post it. It's not that big
its a tp-link and it has ww-drt on it already. It's a tp-link WR1043ND I think
