Budget Wireless Router
- Re: Budget Wireless Router
02-11-2014 10:09 PM
Since having my Fibre broadband installed ive had nothing but problems with the wireless dropping out all the time
Can anyone recommend any decent wireless routers with a maximum price tag of around £80.
I rely on the wireless a lot so wireless is important to me
02-11-2014 10:37 PM
As a side note, I run a local cache per AP as follows.
03-11-2014 6:34 AM
http://www.amazon.co.uk/Asus-RT-N56U-Wireless-Hardware-streaming/dp/B004TPWRSK
03-11-2014 7:36 AM
03-11-2014 10:59 AM
Both ADSL & fibre so future proof. 2.4 & 5Ghz wifi.
03-11-2014 8:18 PM
03-11-2014 8:55 PM
Your best option is...
"Built-in VDSL2 Modem for Fibre Broadband up to 100Mbps!"
http://www.broadbandbuyer.co.uk/products/17047-tp-link-td-w9980/
A regular visitor to plusnet has a review here http://www.kitz.co.uk/routers/tplink_TD-W9980_review.htm
Yes it will do away with the bt gear.
03-11-2014 8:59 PM
Quote Yes it will do away with the bt gear.
Why would I want to do away with the BT modem?
03-11-2014 9:06 PM
Quote from: willas00 Because of the way fibre works would this ASUS device replace the Plusnet box?
You don't unless you want to use just a single box and be eco-freindly tijara33
03-11-2014 9:36 PM
The Kitz forum has a list of combined router-modems that do away with the Openreach modem. I think people on the list seem to like one of the Zyxel models...
http://forum.kitz.co.uk/index.php?topic=14436.0
I have been running two separate boxes, and use the TP-Link WDR3600 as a router. Right now, I'm very pleased it does simultaneous 5GHz and 2.4GHz wifi.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
03-11-2014 9:40 PM
Both are on different sides of the room so just looking to replace the Plusnet fibre router
03-11-2014 9:43 PM
03-11-2014 9:58 PM
04-11-2014 10:34 AM
The wan diag is basic, but more than you get from the PN box, without hacking the BT modem.
DSL
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/B/L/M
Upstream Downstream
Current Rate (Kbps) 20000 65358
Max Rate (Kbps) 26768 75796
SNR Margin (dB) 9.9 5.9
Line Attenuation (dB) 13.2 13.7
Errors (Pkts) 0 0
Is the status report on the front page.
04-11-2014 6:19 PM
its a tp-link and it has ww-drt on it already. It's a tp-link WR1043ND I think
