BT Wholesale Broadband Performance Test Faulty
scrookes
Fixes: 4
Re: BT Wholesale Broadband Performance Test Faulty
Sent over yours too @snadge.
Interesting thread I found on the BT Broadband Community this morning:
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Re-Up-to-38MB-or-52MB-which-am-I-on-Technic...
Seems they are also getting the error messages when running performance tests.  I've flagged that post to our Wholesale supplier as they were getting the same error:
Results Image not loaded
1. Best Effort Test:
Download Speed : xx Mbps
2. Upstream Test:
Upload Speed : xx Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Hopefully we'll get some traction now I have proven this is also affecting BT Consumer Broadband circuits.
goldenfibre
Seasoned Pro
Fixes: 12
Still the same.
Download Speed : 74.98 Mbps
2. Upstream Test:
Upload Speed : 17.27 Mbps
scrookes
Fixes: 4
It may take a while for them to resolve. I'll keep you all updated
jwsg
Same problem here
scrookes
Fixes: 4
We've raised quite a few circuits to BT now and in all cases they appear to be FTTC.  Seems that we have enough at the moment for them to identify the root cause and they have advised me that this is being looked at.
I don't currently have a timescale for fix, so for the time being would suggest for everyone to use an alternative performance tester, especially if you are wanting to highlight any issues off the back of a raised fault into Plusnet.
As before, I will keep this thread updated as soon as I hear anything else from BT.
SpendLessTime
Fixes: 86
@scrookes
If my FTTP line is showing as FTTC then that maybe a different issue for mine .Smiley
JayG
Fixes: 6
Just for the record, my connection is ADSL2+ and I get exactly the same error message on further diagnostics as the OP (and have done for a week or so now.)
Over the years I've got used to it being rather hit and miss. Roll_eyes
scrookes
Fixes: 4
@JayG That's interesting information and will pass onto BT.
@SpendLessTime Your FTTP will likely also be affected.  I should have said any FTTx circuit is likely to be affected by the issue.  My bad
DS
Seasoned Champion
Fixes: 22
scrookes wrote: (snipped) It may take a while for them to resolve.
BT on the case.JPG Same old same old .... At least they're on the case!! Roll_eyes
Thanks Smiley
goldenfibre
Seasoned Pro
Fixes: 12
I think it time for BT to add IP Profile stamp via Plusnet member account with phone number rather than using BTw speed test with a hit and miss at all times and BT never learn from this to fix this.
MrSilver
Fixes: 9
Hi
Think its working now, can you all check too just in case I am an anomaly Cheesy
Strat
Fixes: 565
Worked for me now Smiley
goldenfibre
Seasoned Pro
Fixes: 12
Stlll not working Sad
FAQ
Download Speed : 74.99 Mbps
2. Upstream Test:
Upload Speed : 17.56 Mbps
goldenfibre
Seasoned Pro
Fixes: 12
I did try twice but still not working. Sad
FAQ
Download Speed : 74.96 Mbps
2. Upstream Test:
Upload Speed : 17.58 Mbps
DS
Seasoned Champion
Fixes: 22
Working here too - hooray!!! Smiley
But kinda wished it wasn't - This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault. - booooo!!! Knuppel
