Asus DSL-N66U fibre woes
- Asus DSL-N66U fibre woes
Re: Asus DSL-N66U fibre woes
12-01-2015 2:37 PM
I changed the DSL modulation to 'ADSL2' on the DSL Settings screen but yeah, that's obviously not needed. My mistake.
12-01-2015 3:10 PM
Id like to help maybe with teamviewer.
12-01-2015 3:25 PM
I'd be happy to take you up on that - thanks! I've gotta do a quick bit of work for a client and will pm you my teamviewer id. I should be available shortly after 4pm so any time that suits you after that works for me.
12-01-2015 3:53 PM
12-01-2015 4:23 PM
12-01-2015 4:33 PM
12-01-2015 5:33 PM
If that is what you have set, it WILL NOT WORK.
12-01-2015 6:40 PM
12-01-2015 9:17 PM
I now use a ZyXel SBG3300-N which is rock solid. My advice take it back and get a refund.
13-01-2015 3:23 PM
13-01-2015 6:25 PM
This file is The first version of utility for ASUS DSL-N66U inside are Utilities: Router Setup Wizard / Device Discovery / Firmware Restoration / Printer Setup.
Hopefully this will work the way it should afterwards
13-01-2015 7:00 PM
14-01-2015 10:44 AM
Redbull has been extremely helpful (including taking the time to do a teamviewer session). He's given me a couple of extra things to try but I've been snowed under with work. I'll try his suggestions this afternoon and update this thread with the results.
Asus support got back to me after I sent them a log file and are claiming it might be faulty batch, but in light of other users having similar problems with Asus routers, I'm not convinced.
In case I have no luck this afternoon, does anyone have any recommendations for combined router\modem around the £150 mark? I develop streaming video software so I need something with a very stable wireless connection, NAS support, built in VPN support, easily configurable DHCP range etc.
14-01-2015 11:33 AM
http://www.tp-link.com/lk/products/details/?model=TD-W9980#over
You can purchase from here:
http://www.broadbandbuyer.co.uk/products/17047-tp-link-td-w9980/
It has been extremely rock solid as have the wireless side of things. I know TP Link may not be as sexy as some of the ASUS Kit but it just seems to work in my experience.
Seems to tick all your boxes apart from it's a lot cheaper than £150 but only allows VPN Passthrough, so no VPN Server that I can see.
Cheers.
14-01-2015 12:44 PM
I thought it had VPN endpoint support. Just checked the manual and it does , page 40.
Quote so no VPN Server that I can see.
