webstats missing (again)?
- Everything else
- webstats missing (again)?
29-08-2010 7:18 AM
Nothing on the service status.
Is it the same for everybody?
Tony
Re: webstats missing (again)?
29-08-2010 10:52 AM
Quote from: Tony Is it the same for everybody?
Not here yet, either 😕
Just looked on Service Status to see if there'd been maintenance of some sort this weekend, but the most recent shown was for Tuesday 24th August. Usually it seems to have been some sort of systems overhaul having happened that throws the webstats out or makes them late, but not this time, I don't think.
May be worth raising a ticket to make sure this gets flagged up somewhere, might not get noticed otherwise, being a bank holiday weekend.
Regards,
Penny.
29-08-2010 12:04 PM
Just had a phone call from Business Customer Support - I rang them at 7.30 this morning and they said that they would ring back between 9 and 10am.
The CS person said that networks are looking into it. I said that it wasn't just me that was affected, but he offered no more information regarding a time scale for their generation. I said that the script needed to be run manually (I also said this at 7.30 this morning).
I wouldn't get your hopes up before Tuesday as it is a bank holiday.
Still nothing on Service Status.
Tony
29-08-2010 12:26 PM
Quote from: Tony The CS person said that networks are looking into it.
... well, that's a good sign. Networks almost always manage to fix it "on the day" - so long as they know, that's the main thing.
Quote from: Tony I said that the script needed to be run manually (I also said this at 7.30 this morning).
... raised a ticket at 11.04am (#34926830) and, like you, asked if someone could start the run manually. I also linked to this thread so that whoever in Networks the ticket gets passed to, can hopefully put an update here even if Service Status doesn't get done.
Quote from: Tony I wouldn't get your hopes up before Tuesday as it is a bank holiday.
Would have been less hopeful if "just one ticket" raised and no response, but given you've had a call back already and Networks are definitely on the case, should all be fine, I trust 😕
Regards,
Penny.
29-08-2010 1:39 PM
David
29-08-2010 3:38 PM
Tony
29-08-2010 4:59 PM
Quote from: Tony the webstats are now available.
Both sets have arrived here also - however I might just leave the ticket open until there's some advice from Networks as to why the auto-run didn't happen - if there was a 'problem' generated (63069, thanks David) then something must have happened to stop them running as normal.
Realise it's bank holiday weekend so we probably won't get an update till Tuesday 😕
The stats themselves much appreciated, though.
Regards,
Penny.
30-08-2010 8:51 AM
Once again thanks for flagging this with us. I have had a look at problem 63287 this morning and can see that this should have indeed been resolved fully.
Looking over the notes from the engineering team it appears for some unknown reason the stats failed to be copied correctly from one server to the other and had to be completed manually.
If you find you do raise a ticket on the webstats and find its not been answered within a couple of hours please do give us a call so that we can deal with this as quickly as possible, more often than not we're already onto the problem but sometimes things like this do get missed.
Hope you all have a great bank holiday and any problems give us a shout
30-08-2010 9:51 AM
- Keith D.
30-08-2010 12:12 PM
Quote from: fusian Looking over the notes from the engineering team it appears for some unknown reason the stats failed to be copied correctly from one server to the other and had to be completed manually.
Many thanks for the update on what caused yesterday's issues and to the engineering team for the fix.
However, as Keith pointed out, today's Webstats haven't materialised on schedule - maybe the same issue?
As requested I have updated Ticket #34926830 and also put in a call to Support, and was told that Webstats are already in the 'monitoring system' and that a new problem will be raised now so that this can be looked at again.
Regards,
Penny.
30-08-2010 12:55 PM
Thank you all for raising this with us and please accept my apologies that this issue has cropped up again. We have now raised a further problem on ref: 63294 and Sarah from the networks team has performed some triage to get the webstats for today up and running and although they will be a little late, they wont be lost.
We are also keeping the problem open for further investigation to be completed tomorrow when the Networks team are back in the office to try and get to the bottom of whats causing the problem. I will keep an eye on this myself tomorrow and ensure the webstats are run if they don't complete automatically.
I hope your all having a good bank holiday
31-08-2010 11:17 AM
We have now isolated a problem with a missing file which was causing the script to fail and this has now been resolved, as such you shouldn't have any further difficulties with the webstats running automatically.
If you do see any problem please do let us know and we will pick these up asap for you
Thanks.
- Everything else
