rDNS Change
FIXEDTopic Options
- Everything else
- rDNS Change
20-12-2022 4:17 PM
Hi
Would it be possible to get my rDNS changed as its no longer possible through Help Assistant.
Fixed! Go to the fix.
Message 1 of 3
(1,217 Views)
2 REPLIES 2
24-12-2022 5:38 PM
Hey there, sorry about the delay in getting back to you. I hope you're ok and everything is sorted for xmas.
Please can you send me your username via PM and I will definitely get this sorted for you? ![]()
Message 2 of 3
(1,133 Views)
Re: rDNS Change
24-12-2022 7:43 PM
PM Sent 😊
Message 3 of 3
(1,115 Views)
