Master Socket Move Request
Mattb30220
As others have experienced, I'm having no luck getting through to anyone on the phone and would like to book to have my master socket moved. Is it possible to arrange this via a ticket through the forum?
Many thanks.
3 REPLIES 3
Gel
Champion
Fixes: 29
Re: Master Socket Move Request
RealAleMadrid
Fixes: 68
@Mattb30220  If you arrange it through Plusnet Openreach will charge an extortionate price of £160. @Gel's suggestion of finding a local engineer is likely to be  more reasonable. Your choice of course.🤔
willcutforth
Fixes: 113
Hey there @Mattb30220 and welcome to the forum.
As @Gel and @RealAleMadrid have suggested, it would more than likely be cheaper to get a local engineer but our provisioning team can look into it if you want to do it through Openreach.
 Will Cutforth
