no-one can access my website that is on a domain hosted on plusnet. It worked unti 14 Oct 2025
AMcG
Account username: [Removed]
Our Support Team have opened Question 251145592 to track an issue on your account.
I was advised by
<Redacted> from the "technical team" the best way to get the issue resolved was to post here. Apparently his team doesn't have the permissions to change the required settings.
THe domain is mcgregoropticians.co.uk
apparently, ( my IT advisor tells me) the problem is
The website still exists on your host (as of this morning at least), and nothing has changed for several weeks at my end. I was able to remotely access the website via an editing program and inspect the files as normal, although connection with the host seems inconsistent.
So, it seems apparent that a change or misconfiguration has occurred at your hosting provider - either an error on their part or (hopefully not) someone has got access to it that should not have.
Your domain is supposed to lead directly into the htdocs folder, using that as the root directory, but it is instead pointing to the parent directory. This suggests a misconfiguration has occurred. There may be a permissions error. It could be as simple as resetting the root directory to point to /htdocs.
I hope this will give enough information for someone from PlusNet to solve the problem.
Moderator's note:
CSA name(s) removed (to an area staff can see) as per Forum rules.
Moderator's note by Mike (Mav): Personal information removed from a public forum (to an area that staff can see).
44 REPLIES 44
Fixes: 235
Re: no-one can access my website that is on a domain hosted on plusnet. It worked unti 14 Oct 2025
@dave
Is this another hosting issue to review please... or just an empty website?
mcgregoropticians.co.uk points to 212.159.8.91 / 212.159.9.91
Which appears to redirect to www.mcgregoropticians.co.uk which points to...
Address: 91.204.210.11
Aliases: www.mcgregoropticians.co.uk
homepages.force9.net
hp.force9.net
Fixes: 235
@Leanne_T
Can you please push this direct to the tech guys running with the mail service migration please?  I suspect that @dave is up to his ears with alligators elsewhere!
Leanne_T
Thanks @Townman
@AMcG this has been raised to the relevant team and we will post an update once they get back to us.
Leanne.
Leanne_T
Hi @AMcG
That should be sorted now for you. They have advised, they have made a change in the DNS so the site may be a little intermittent for the next half an hour or so.
Thanks.
Leanne.
AMcG
Thanks for the help, BUT  I have justtried to access the website and it is not working I just g
Index of /
[ICO] Name Last modified Size Description
[DIR] htdocs/ 2025-10-14 15:58 -
Apache/2.4.58 (Ubuntu) Server at www.mcgregoropticians.co.uk Port 80
et the same message:
Fixes: 235
@Leanne_T
It would be good to know exactly what the team changed.  My DNS lookups (into Plusnet's DNS) are the same as yesterday.
Thank you for trying.
Champnet
Fixes: 18
@Townman  Can you see the site ?
Fixes: 235
I see a directory listing (I did yesterday) but it is empty.
No one has clarified if the site really is empty or the URL is pointing to the wrong resource.
EDIT: Double checked - yes I do - someone must have just fixed it (following another flag-up)!
EDIT2: On reviewing my look ups, I can see that two IP addresses are being returned for the www. version - one is clearly right, the other looks suspect, so seeing the site correctly could be hit and miss.
Champnet
Fixes: 18
Strange, I weas seeing it upto a few minutes ago but now it just looks like a empty site.
The site should really be moved, It's a very professional site but with no HTTPS security.
Just to confirm my sighting the Opticians are in a place reknowned for producing footballers.
**Edit : Back up again
Fixes: 235
You are experiencing the confused state of the DNS resolution for the URL...
Server: ordns.he.net
Address: 2001:470:20::2
Non-authoritative answer:
Addresses: 91.204.210.11
212.159.8.90
hp.force9.net
212 is correct, 91 is not.
Leanne_T
Morning @AMcG @Townman
Could you try again and let me know if you have any problems accessing the site?
Thanks Smiley
Leanne.
Fixes: 333
@Leanne_T I'm neither of those mentioned, but I can confirm the site now appears to load correctly. FYI, though, I am not on a Plusnet connection.
Leanne_T
Thanks for trying and letting me know @jab1
Leanne.
Fixes: 235
@Leanne_T
I checked late last night; eventually the DNS resolution delivered a single IP address - the one on Plusnet’s platform.
Thank you for the follow-up, but more importantly detailing the cause of the issue.  Such insights enable the community to grow it’s self help capabilities.
