login problem
ancientrustic38
login problem
This is my first attempt to  login to my ccgi space. I've used the username and password from the email I received earlier in the year but am constantly denied access. Help! Sad
12 REPLIES 12
Oldjim
Resting Legend
Fixes: 63
Re: login problem
spraxyt
Resting Legend
Fixes: 75
Re: login problem
It's possible your account has been disabled. As mentioned in that FAQ
[quote=http://community.plus.net/hosting-faqs/]
You’re urged to log into your account once you’ve received the email. This is to ensure your account stays active.
Any accounts that aren’t being used a month after the migration will be disabled.
I suggest raising a hosting ticket at https://www.plus.net/wizard/?p=wizard&page=23101&wizard_id=38
David
bobpullen
Fixes: 316
Re: login problem
We've not disabled any accounts, despite the information contained in the FAQ.
I've reset the password and replied to the OP's support ticket.
Quote from: ancientrustic38
This is my first attempt to  login to my ccgi space...
You've changed your password from the temporary one we initially set so you must have logged in at some point in the past.
Did you try using the forgotten password link before you opened a support ticket?
Strat
Fixes: 565
Re: login problem
I've tried the 'forgotten password link' as I've forgotten my password but nothing happened.
bobpullen
Fixes: 316
Re: login problem
The forgotten password function will send a message to the email address we have on file. Unless I'm mistaken Strat, this doesn't seem to be a valid mailbox? The same applies for the email address we have on file for your Plusnet account?
I've changed the Hostopia email address to your postmaster mailbox. I'd be interested to know if you have any more luck now?
Strat
Fixes: 565
Re: login problem
My billing emails go to both my force9 account address and my domain address.
I'll have a retry of the 'forgotten password' in a bit.
bobpullen
Fixes: 316
Re: login problem
Thanks.
Quote from: Strat
I can see that, however I see no reference to the domain mailbox when I look here. As far as that seems to be concerned, it doesn't exist? Huh
Strat
Fixes: 565
Re: login problem
Yep, I get a  "500 Internal Server Error".
I did a rebuild of my PC a few weeks ago and have lost some emails including the CGI access details so I'm at a dead end.
bobpullen
Fixes: 316
Re: login problem
500 server error!? Huh
I can't replicate that no matter what account I try, nor what details I enter into the password reset form.
In fact, I've just tried resetting the password for your account and this was returned:
I suspect you'll find a copy of that email in your mailbox when you check?
Strat
Fixes: 565
Re: login problem
I've had that message a few times but unlike mine, yours has produced an email Smiley
bobpullen
Fixes: 316
Re: login problem
Might be due to the username you entered. I don't think there's any validation done, so it will return that message whether it finds a matching account or not. The username convention for the Hosting Control Panel may not be obvious at first. It's your CGI HTTP address e.g. ccgi.username.plus.com.
Strat
Fixes: 565
Re: login problem
Sorted and thanks very much to Bob for sorting it.
Apologies to ancientrustic38 for hijacking their topic Embarrassed
No doubt I'll have a Mod on my back now Lips_are_sealed
