Domanins: www.iceberg-innovations.org.uk
- Everything else
- Domanins: www.iceberg-innovations.org.uk
18-08-2014 9:00 PM
Now can I fix this
Message 1 of 5
(2,413 Views)
4 REPLIES 4
Re: Domanins: www.iceberg-innovations.org.uk
18-08-2014 10:07 PM
Welcome to the Forums
Poll removed
Can you give a full explanation of what the problem is please as the visible page source doesn't help
Poll removed
Message 2 of 5
(264 Views)
19-08-2014 5:05 PM
It's a Madasafish-hosted domain.
To make alterations to the website, you will need to FTP to your webspace and modify the files you have uploaded.
The FTP address is www.users.freenetname.co.uk and your login credentials are the same as those used to log into the Madasafish website.
Message 3 of 5
(264 Views)
19-08-2014 9:53 PM
Quote from: ZaraBall can I fix this
Hi ZaraBall,
I've looked at the source code (right-clicking the visible page at http://www.iceberg-innovations.org.uk/ to "view source") and it looks like some code (including maybe <img) has got missed off before src= .
I wasn't quite sure what the page was intended to do (and don't know the first thing about "frames") so have written you some very basic html which has links to the two pages I thought you might wish to be referring to, either via link or an automatic forward.
I have made two pages, each with the "meta tags" at the top, similar to those on the page currently at http://www.iceberg-innovations.org.uk/ . Both these "made pages" have links to "Iceberg Innovations" and "The Old Sod", but both also have "automatic forwards" so after seven seconds each page will go to the new address.
I don't know how clear the above explanation might be : / but the "made pages" are:
(1) http://www.signpost.plus.com/test/index.htm which will forward, after 7 seconds, to http://www.iceberg-innovations.org.uk/iceberg.htm
(2) http://www.signpost.plus.com/test/index2.htm which will forward, after 7 seconds, to http://apotos.info/
Hopefully the source code of each of the "made pages" might serve as a basis for you to create the actual content and re-direct that you're looking to achieve. The software the pages were built with, Arachnophilia 4.0, can be downloaded free of charge at http://www.arachnoid.com/arachnophilia/index_old.html.
If you make your new page and upload as index.htm to your www.iceberg-innovations.org.uk site (via the FTP that Bob mentioned above) your new page should work okay, probably.
Hope this helps : )
Penny.
Penny Rollo * Force 9 from 17/02/98 * PlusNet from 2000 onwards
Project HappyChild - free worksheets, maths, languages, spellings, all sorts - page *here* re linking languages across the world - see also the freeway page
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Message 4 of 5
(264 Views)
12-09-2014 12:57 AM
... the above post wasn't replied to, but the content of the referenced page at http://www.iceberg-innovations.org.uk/ was at some stage modified so that it regained the appearance of the page originally at http://www.iceberg-innovations.org.uk/iceberg.htm (the latter now generating a 404), so I thought I had best put some explanation here as my original post makes less sense, now : /
Also when tested just now the second address (apotos) brought up a "possible virus" warning from AVG Free.
Accordingly I have modified the original link to Iceberg Innovations to the main domain address, and changed the second link to BBC News. I'd have modified the original post above but the "edit" facility seems to have disappeared (time-lapse factor, maybe).
As per the original post the two pages have "meta tags" at the top, similar to those on the page currently at http://www.iceberg-innovations.org.uk/ . Both these "made pages" have links to "Iceberg Innovations" and "BBC News", but both also have "automatic forwards" so after seven seconds each page will go to the new address.
(1) http://www.signpost.plus.com/test/index.htm will forward, after 7 seconds, to http://www.iceberg-innovations.org.uk
(2) http://www.signpost.plus.com/test/index2.htm will forward, after 7 seconds, to http://www.bbc.co.uk/news
Hope this might help clarify things if anyone reading this didn't see the (working) links from the original 'test' pages at the time my original post was made.
Regards,
Penny.
Regards,
Penny.
Message 5 of 5
(264 Views)
- Everything else
