ccgi webspace not responding
bobpullen
Fixes: 330
Re: ccgi webspace not responding
@MisterW - yep, absolutely - and things look OK from an account standing so I'm scratching my head why the DNS record remains absent.
Might have to defer to @plusnettony for some help with next steps.
plusnettony
Fixes: 73
I'm looking...
 Tony T
Fixes: 580
@bobpullen
We really are in trouble if you're scratching your head.
@plusnettony I'm assuming this doesn't affect all accounts so just thinking what might be unique to mine...
1) Its on the IPv6 trial but I cant see why that would have anything to do with it
2) It used to have a hosted domain but that was transferred away a couple of years ago. However I probably havent used the cgi space in anger since then.
plusnettony
Fixes: 73
Thanks - it seems to be just a few users (me included). I made a change the other day as cgi wasn't pointing right, then Bob spotted a component which wasn't right. Since that was corrected, and the CCGI still seems to be pointing at the right space, I'm a little lost. I am working with a colleague to take another look though.
 Tony T
bobpullen
Fixes: 330
I suspect it broke a long time ago when you last changed your account password. This has a habit of 'refreshing' certain components on your account - and where the CGI component is concerned - it knocks it into a bad state and causes the DNS scripts to overlook it.
Typically, fixing the component would allow the DNS scripts to rebuild the A record but for reasons unbeknowst to me - this isn't happening 🤔
Fixes: 580
@bobpullen
that sounds feasible.
I probably changed the ccgi password at the same time and they are different
Dont know if that's significant ?
plusnettony
Fixes: 73
It seems to be to do with the proxy. I raised to Greenby earlier as it wasn't pointing correctly. I don't have access to my work email at the moment, so not sure if they've replied, but if they have, it will still need a DNS update. I'll be checking tomorrow.
 Tony T
Fixes: 580
@plusnettony any response from Greenby ?
plusnettony
Fixes: 73
Not as yet - i am chasing
 Tony T
twild
@plusnettony did this issue get resolved?
I've just tried a couple of times in the last couple of days to access my own pages at
ccgi.<username>.force9.co.uk and get the message:
This site can’t be reached
plusnettony
Fixes: 73
Yes, that was resolved. I'll see if I can find anything on yours.
 Tony T
