ccgi webspace not responding
argonot
Having worked flawlessly for years, regular uploads of weather data to my ccgi website started to fail on 29th July at 18.45. The weather station software logs show an error, 'Name or service not known'. The error repeated for another four uploads, after which they resumed as normal until another failure at 20.25 with a different error, 'Temporary failure in name resolution'. After that, there were no more successful uploads and the original error was reported each time.
One DNS lookup showed for CNAME:
Domain name ccgi.xxxxxx.force9.co.uk
Canonical name ccgi.xxxxxxx.f9.greenbysites.com
This suggests that Greenby are involved.
I have had no communication from Greenby about any migration of email or websites, so have no way of contacting them. Email and my homepages website are working normally.
I'm hoping that someone from Plusnet technical support might read this and help with a solution.
40 REPLIES 40
ExForce9
All Star
Fixes: 11
Re: ccgi webspace not responding
Perhaps @bobpullen can take a look, or knows the internal guru who can solve this ?
PhilipHeyes
Seasoned Champion
Fixes: 27
The Greenby Portal is at : www.greenby.com
The Credentials are the same as for the Plusnet Members Centre.
argonot
Thanks but,
"Your Greenby login will only be activated after your migration is complete. We'll notify you by email as soon as it's ready."
plusnettony
Fixes: 78
Everything is still with us.
I've checked the account (the one you provided in your forum profile) and after a quick look i can't see anything obvious wrong on our side or at Hostopia.
When you FTP in, can you see your files as you'd expect?
 Tony T
argonot
Thanks for responding, Tony.
When I try to connect via FTP , the immediate response is 'Connection failed'.
argonot
I should have added that traceroute to the server produces 'unknown host'.
Fixes: 585
@plusnettony its a while since I used my cgi space.
Should FTP to ccgi.<account>.plus.com still work ?
It doesnt , and nslookup ccgi.<account>.plus.com reports 'Non existent domain'
plusnettony
Fixes: 78
Thanks for the follow up, and @MisterW I'm getting the same. I'm speaking to someone about it now.
 Tony T
argonot
What about ccci.<account>.force9.co.uk?
argonot
Sorry about the finger twitch - ccgi.<account>.force9.co.uk
plusnettony
Fixes: 78
I've asked a colleague to do some tweaking (awaiting DNS to update on our side). I'm hopeful this will sort it, but if not, I have a plan.
 I will check back tomorrow, but if the changes work, I expect them to be seen later today.
 Tony T
argonot
Thanks for your help - fingers crossed that fix will work.
pjcs
My ccgi address has disappeared
It is currently returning "This site can’t be reached. ccgi.xxxxx.force9.co.uk’s DNS address could not be found. Diagnosing the problem" in my web browser, and attempts to FTP to it fail to connect. Please can someone investigate?  Thanks.
Fixes: 585
Re: My ccgi address has disappeared
@pjcs Fix already in hand , see https://community.plus.net/t5/Everything-else/ccgi-webspace-not-responding/m-p/2054394#M41988
