VoiP on Full Fibre - phone port on Hub Two?
Vintage58
Hi there - just upgraded to Full Fibre, and everything seems fine. Currently contemplating adding Third Party VoIP, and was intrigued to notice the stickered-over Phone Port 'for Digital Voice Customers Only' on the Hub Two. If we go with third party VoIP (e.g. with A&A), can we just plug our existing DECT phone base station (previously on our landline) into this port? Will that work (hence save quite a bit of dosh on buying a new handset/base)? I've used office VoIP systems but am new to the domestic possibilities!
Tags (1)
5 REPLIES 5
Fixes: 558
Re: VoiP on Full Fibre - phone port on Hub Two?
@Vintage58 the phone port on the Hub 2 is non functional.
Fixes: 1,491
Moderators Note
This topic has been moved from Full Fibre to Everything Else
Vintage58
@MisterW thanks! Obviously provided for when it's a BT device and disabled in firmware, then. No probs, just means I have to decide whether VoIP is worth buying the new hardware for
Fixes: 1,491
You'd just need an ATA adapter such as a Grandstream HT-812 which you can plug your DECT phone into.
Cost should be under £50.
Fixes: 558
@Vintage58  exactly!
