Power cut timing?
JPN
Power cut timing?
I've been away for a while, and come back to find the mains power off - the RCD had tripped.   It would be useful to know when this happened. Could Plusnet systems identify the time/date of the outage? There has been no power since the trip, so presumably the modem being off would register with Plusnet?  (All back to normal now).
7 REPLIES 7
Re: Power cut timing?
@JPN
The Hubs event log might give you a clue, if it's a Plus Hub and you're not sure where to look I can guide you.
HTH
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Everything Else
JPN
Thanks for that suggestion, I should have thought of that!  I have now checked the router log (TPLink TL-WR940N) but it only starts when the power came back on this afternoon, nothing before that.
That's a annoying feature of some TP-Link modem/routers, hopefully someone from plusnet can help.
RobPN
Fixes: 15
@JPN
Probably not much use to you on this occasion unless you've already set it up, but I've found checking my BQM at thinkbroadband.com useful sometimes to check timings where the power has failed or my router has 'frozen'.
see - Broadband Quality Monitor
JPN
Thanks for that RobPN. Interesting capability. I'm not sure I'd need it for any regular monitoring, but as you say a useful way of getting an outside view of what has been happening.
JPN
It was a bit of a longshot, but I guess the timing info is not available.  Thanks Dan and RobPN for the assistance.
