Domain Transfer
sgrant
Domain Transfer
Hi
I need to transfer both the hosted domains to another provider.  I have an IPS tag which needs changing from "WEBCONSULTANCY" to "IONOS".
Could someone please help me out with this?
Thank you
Regards
Stephen
2 REPLIES 2
Fixes: 585
Re: Domain Transfer
@sgrant I didnt recognise the IPSTAG 'WEBCONSULTANCY' so looked it up https://registrars.nominet.uk/uk-namespace/registrar-agreement/list-of-registrars/ .
It appears to be https://easily.uk/ , so it would appear that the domain is not registered by Plusnet. If that's the case then you need to do the transfer through the current registrar
sgrant
Re: Domain Transfer
Thanks @MisterW, I've contacted the registrar to see if they can help
