VPN not working
Foxearth
Re: VPN not working
Hi folks
I'm having the same problem. Could connect to my work VPN fine until a few days ago, now I can't. Works OK via a mobile hotspot but not via my Plusnet router, either by LAN cable or wifi. My work IT believe this is an ISP issue at my end, hence this post. I've tried rebooting and the port clamp enable tip, but neither resolved the issue.
Please can someone from Plusnet Support PM me to get my details to try the session kill fix?
Many thanks
Rob
Fixes: 1,663
Re: VPN not working
Hi Rob
Sorry to see your VPN has stopped working.
I've checked things this side and I can't see any changes within the last few days. I've also checked your connection and until around 15 minutes ago, you've been on the same IP address for around 9 days.
As you've got a different IP address now I don't think a session kill is necessary or will fix the issue. It also doesn't look like the issue is IP related as you've had the same one for 9 days and you've said the issue only started a few days ago.
Do you get any particular error when you're unable to use your VPN? What router are you using too?
Foxearth
Re: VPN not working
Hi Gandalf
Thanks for the quick reply. Yes, I turned off my router for 15 minutes and then got an IP in the 51.x.x.x range rather than the 143.x.x.x range I had before, and was then able to VPN to work fine again Smiley
For info, though, the message was an "unable to access gateway server " at my work's https server address. I am on a Plusnet Hub One.
Cheers
Rob
Fixes: 1,663
Re: VPN not working
Hi Rob
Cheers for getting back to me,
It's good to see that the change in IP fixed the problem for you. Thumbs_Up
As a heads up it's not very often a reboot of the router or a disconnection will move you to a different dynamic IP address as you'd get assigned a dynamic IP from a very small pool that's specific to your location so they're quite sticky and you'd generally get the same one back
Hopefully you don't have anymore issues though but if you do feel free to yell
bignose
Re: VPN not working
Hi Guys
Ive just moved to Plusnet from Vodafone and have run into my VPN not working from midday today
reading this thread is interesting ... so the 145.***.***.** range is blocked as its registered in the US is that correct ..???
can you make an IP static that actually lets me use my VPN for work Huh
Fixes: 585
Re: VPN not working
is blocked as its registered in the US is that correct ..Huh
No, the IP range IS registered in the UK. The problem is that some third party geolocation providers think it's registered in the US and seem incapable of correcting their databases!
You can request a static IP via the member centre, there's a one off charge of £5. Static  IPs are from a different range.
MatthewWheeler
Fixes: 503
Re: VPN not working
Thanks for getting in touch @bignose
You're not actually connected on the IP range mentioned above so that shouldn't be the cause of your issue.
Can you advise what error you get when you try to connect?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
bignose
Re: VPN not working
thanks for the info ... its seems to happen around 1:30 yesterday and today ... I have access through the morning and then have to access via my phone hot spot in the afternoon Huh
JOLO
Fixes: 77
Re: VPN not working
@bignose,
Good to hear it's working, let us know if you encounter any further problems.
JOLO
Fixes: 77
Re: VPN not working
@bignose,
Ignore me, I've just re-read what you've put, sorry. So it happens at half one? It seems strange it's only sporadically occurring. Does it seem to coincide with any event, or any other usage at the time of the problem?
bignose
Re: VPN not working
hi Joe ... nope at the moment I'm on a IP from the 51.**.**.*** range and my VPN is not working
switch to my phone and it will work Huh
sebmak
Re: VPN not working
Hello,
My VPN is currently not working, it worked previously when i was on standard broadband with plusnet, but since upgrading to fibre it has stopped working. I am using OpenVPN. Please help if anyone has solutions?
Regards,
Sebastian
Beyhive
Fixes: 44
Re: VPN not working
Hi @sebmak,
Does it give you any particular error? Have you tried using it on a different device to see if you are getting the same issue there?
 Faris
sebmak
Re: VPN not working
@Beyhive
It connects initially, but when i want to open something up from the server, the VPN will stop working. It works perfectly fine if i were to connect my vpn through a mobile hotspot and then open something etc.
Beyhive
Fixes: 44
Re: VPN not working
Hi @sebmak,
Just wondering if you've tried using VPN on a different device to see if the same issue occurs?
 Faris
