Newbie having problems connecting
- Everything else
- Re: Newbie having problems connecting
20-02-2009 3:02 PM
I'm the first to admit I'm new at this but I have tried to read a lot of the postings here before looking like a complete numpty!
I have requested the trial of PAYH, but on accessing https://plesk-host06.plus.net:8443 I receive a "Internet Explorer cannot open the webpage" error. I have diabled my Finjan web-proxy and am running straight through a Watchguard firewall but I am getting into other sites without problems. Is this because the particular pc I am at today is not connected using PlusNet as my ISP? If not, any suggestions would be greatly appreciated - I have already tried deleting cookies relating to PlusNet and the community forums.
Many thanks,
Gavin
20-02-2009 3:58 PM
20-02-2009 4:15 PM
20-02-2009 4:17 PM
I've tried relaxing the firewall rules as much as I can but still no joy - however I have got someone else who is on a plusnet account to try it and they had no problem. Therefore this is definately a problem with my connection but I don't know what else to try and unfortunately my current connection is the one I will be working from on this project
Gavin
20-02-2009 4:20 PM
20-02-2009 4:28 PM
I like your thinking! The results got as far as:
Tracing route to plesk-host06.plus.net [212.56.83.200]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 10.0.15.254
5 7 ms 6 ms 6 ms be2.er10.thlon.ov.easynet.net [195.66.224.43]
6 6 ms 6 ms 6 ms linx-gw1.plus.net [195.66.224.164]
7 12 ms 12 ms 12 ms 92.core.plus.net [212.159.1.92]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
Annoying to see it so close and yet so far!
Gavin
20-02-2009 4:31 PM
20-02-2009 4:38 PM
20-02-2009 4:47 PM
Thanks for all your help ... off to raise a ticket!
Gavin
20-02-2009 4:50 PM
20-02-2009 4:54 PM
Plesk uses Port 8443 and many office networks have this blocked as it is not a commonly used Port.
Can you check to see if you have this Port open
20-02-2009 4:58 PM
Thanks for the suggestion - I have opened ports 80, 443 and 8443 for https://plesk-host06.plus.net (212.56.83.200) and yet to no avail. My only other thought is if the login portal references any other addresses that I may need to allow through?
Gavin
- Everything else
