Migrate static IP to new service
mikechilli
Hello!
I have just migrated from a Plusnet FTTC connection to a Plusnet Full Fibre connection and I had a static IP on the former - is there a way I can migrate the fact I have a static IP to the new connection (I am assuming it would be a new static IP which I have no issue with) or will this have automatically happened?
I keep forgetting to think about this when I am at home during support line opening hours so posting this to see if I can get an answer whilst I am at work and can make a call!
Thanks!
4 REPLIES 4
Browni
Aspiring Hero
Fixes: 61
Re: Migrate static IP to new service
It should have happened automatically.
eta: Welcome to the forum!
Fixes: 577
Assuming you have upgraded the exiisting account rather than start a new one, then the the static IP. should remain the same
Fixes: 475
Moderator’s Note
This topic has been moved from Broadband to Everything Else
SammyM
Fixes: 101
Hiya @mikechilli
Cheers for getting in touch, I appreciate it.
I can confirm that it has followed over with the new product Smiley
 Sammy M - Sheffield Team
