IP Address Wrongly Identied as US Based - Issues with disney +
ItsAlwaysDns
Re: Issues with disney +
@dave wrote:
We've got an incident raised on this and a case open with the geo location service that Disney/Netflix use.
Anyone affected could you check something for me please? Go to this site and tell me if the first 2 digits of your IP address show as 150.143 (I don't need the rest):
https://www.whatismyip.com/
In the meantime, if you turn your router off for 10 or 15 minutes you might get a different IP address from a different range (the algorithm that assigns IP addresses likes to give the same one back a lot of the time so it's not a guarantee). I'll chase up with my colleague that was dealing with the issue tomorrow.
@dave can confirm 150.143, appreciate the assistance.
sunnysideal
Thanks for your help Dave, I am indeed on a 150.143.x.x address.
Good to know it's in safe hands.
nbhamilt
Yup.me too. 150.143.xx.xx
Krem
I've got the same 150.143.xxx.xxx
nbhamilt
Ok. Now ITV x thinks I'm not in the UK. So this problem is growing. I think Plusnet does need to deal with it swiftly.
AyToZed
What do the details registered with ARIN say in regards to your current IP?
https://www.arin.net/
AyToZed
Found it.
https://search.arin.net/rdap/?query=150.143.1.1
Using the 'raw' data from ARIN (without further checks) is a bit braindead (IMO). The location could also be Virginia or Texas. Or even elsewhere.
rawedge
also on the same IP range
Fixes: 382
See post #29 - it is in hand.
Shaunwood
I am also 150.143.xxx
Thank you for taking this on. Fingers crossed it gets resolved soon.
DTC
Re: My IP resolves to US, not UK.
I'm 92.40, would this be picked up in this service request?
dave
Fixes: 19
92.40.x.x belongs to Three Mobile, are you tethering at the moment?
Dave Tomlinson
Plusnet Technology
DTC
Sorry, yes. Please accept my apologies
DTC
It is 150.143
sd77
Same issue here.  IP 150.143.19.xxx
Have tried powering off router for a new IP but keep getting the same block.
