IP Address Wrongly Identied as US Based - Issues with disney +
- Everything else
- IP Address Wrongly Identied as US Based - Issues w...
Re: My IP resolves to US, not UK.
10-03-2026 1:01 PM
@sd77 You will, IP''s are sticky, and short power off's will most likely return the same IP.
10-03-2026 1:24 PM
Netflix should be fixed now. Waiting for an ETA on Disney+ and ITVX.
Plusnet Technology
10-03-2026 2:56 PM - edited 10-03-2026 2:57 PM
I have had the same issues and tried rebooting the router to get a new IP block but with no luck. My geoblocking issue is with Discovery+, has there been any contact made with them about using the correct IP registries ?
10-03-2026 3:17 PM
10-03-2026 3:38 PM
Netflix is fixed, unfortunately, Paramount+ is now broken…. ![]()
10-03-2026 6:18 PM
10-03-2026 6:20 PM
@Jammy121 It is currently under review - see post #29.
10-03-2026 7:14 PM
10-03-2026 7:19 PM
It will take as long as it takes - when you are dealing with organisations such as Disney/Netflix, you are dealing with disjointed entities.
10-03-2026 7:25 PM
10-03-2026 8:05 PM
10-03-2026 8:10 PM
when they know, they will let us know - guesstimates don't really help anyone, and some treat such as gospel, and moan when they are missed.
10-03-2026 8:14 PM
10-03-2026 8:16 PM
Best of luck.
10-03-2026 10:06 PM
- Everything else
