Gigaset N300IP & AA (Andrews & Arnold) VoIP Service
JamesCRocks
So the good news is that AA (Andrews & Arnold) appear to have configured my VoIP service with my original telephone number. I said I'd confirm that it had worked so the following are the steps taken:
  1. PlusNet service switched to full fibre, 300Mbs (morning of 3rd April)
  2. Port of original number, 01795XXXXXX, ordered from AA (evening of 3rd April). Bear in mind I had been discussing it with their support people since 20th March.
  3. Port completed by AA (13th April):
    Main Billing Number: 01795XXXXXX
    Porting Date: 13/04/2023
    Porting Time: 10:00
So that should tell some here that you can (at least now) order a port of a number post switch over and it should work (unless, of course, I was just plain lucky).
Anyway, over that same period I posted a couple of threads to this forum and, following advice given, eventually purchased a Gigaset N300IP, connected it to my network and have successfully accessed the unit from my PC.
I have a Panasonic Quad Cordless phone set (KX-TG6824EB) which I understand are DECT and I have connected it to the N300IP with an RJ11 cable.
I am now trying to set up the unit using the following the link available on the AA support site (VoIP Phones - Gigaset N300 - AAISP Support Site and, unfoortunately, I am having some issues Smiley
I have attached a picture of my main screen and my specific problems are:
  • Connection name or number: Left as default "IP1"
  • Authentication name: +441795XXXXXX (I've assumed no need for a "0" after the "+44"). Same for Username and Display name.
  • Authentication password: Er, what? Did I ever get one?
All other settings are defaults.
With respect to other screens, I haven't changed the Number Assignment because I effectively only have one line. The other screens are, well, something of a mystery to me ... I might have been in IT most of my career but I was never in COMMs so...
Anyway, I'm after any advice anyone can supply, preferably from someone who is using AA, the N300IP and a fairly ordinary DECT phone system (non-Gigaset, I guess)
James
12 REPLIES 12
cpc6128
Re: Gigaset N300IP & AA (Andrews & Arnold) VoIP Service
Fine. it's only important to you
Correct. Same as I have.
Log into AAISP Control pages.
Go to Telephony
Click on your number.
Select Incoming
The password to enter into the N300IP settings I believe is the 'SIP Password'.
I'm using a non gigaset DECT phone. I paired it with the N300. It works and rings fine, shows caller number, just lacks some of the extras that a Gigaset phone would have. I don't use mine that much so I don't miss those.
I hope this helps Smiley
Kev
Fixes: 467
The n300 is a dual landline/ voip unit and The rj11 is for connecting to a landline. Unpair your handsets from the panasonic base unit, and re-pair them to the n300, then forget about the panasonic base unit
JamesCRocks
Go to Telephony
Select Incoming
Having a problem there since I don't know my username (think it might have something to do with my telephone number) or login password. I tried "forgot my password" but irt expects some kind of domain after my [potential] username... I tried <telephone number>@aa.net.uk and an assortment of other ideas. Couldn't find anything in my emails either.
It's probably something I specified during setup but for the life of me I can't remember if that's true.
I can do that? I've looked through the settings of one of the handsets (Panasonic KX-TGA682E) and can't find anything.
James
p.s. I'm good at this, ain't I? In my defence, I'm old, LOL!
cpc6128
For the username for the control pages take a look at your e-mail from Andrews & Arnold sales for me it's the one titled 'Port number to VOIP ...'
In that it'll tell you your allocated account login which is the one starting and ending with A, and the one for the control page which for me has 2 letters, 2 digits and ends with '@a'. That's the one you need to use with their control pages.
You will likely need to use 'forgotten password' to set a password the first time.
JamesCRocks
Thanks Smiley
I think it's connected now but I don't really get this disconnect base station (of my quad phone set) thing. I assumed that the base was connected and that would then alow all the connected handsets to work [effectively] as one phone. Even if they do work separately, I can't find anything on the handsets that would allow me to disconnect them from the base station (I googled a manual but nothing in there). I did find a YouTube video which suggested a hidden menu and putting in "£134" ("#134") but it doesn't appear to work. A subsequent video suggested doing something to the base station but that didn't work either. I'm actually beginning to wonder if these damned phones are DECT at all.
Sorry but, like I implied elsewhere, comms isn't really my thing... I'm beginning to think I might need to buy a VoIP phone.
James
Fixes: 467
According to page 26 of tge Panasonic manual therecare 'cancel register' commands
Use the main base unit phone to cancel the other 3. The switch off the main base, you will not be able to use that.
Then register the 3 remaining handsets to the n300 using its registration procedure ( i think its press the button on the front )
JamesCRocks
Wow! That worked for the handset I have in my cellar. I downloaded a manual as well (I'd seen it before but was obviously searching on the wrong stuff).
So, it's:
#131 to cancel (deregister) a handset
#130 to add (register) a handset
I called from my mobile and it rings, I can answer and hangup but if I hangup without answering it stops ringing but my mobile keeps ringing for perhaps twenty odd rings... a bit strange.
#104 Name handset doesn't seem to work. The one I got to work was named "CELLAR" but now seems to have no name... maybe if I deregister / register the others they'll remember their old names? It would be nice to have that back as maybe the INTERCOM function (calling between handsets) would still work.
Anyway, thanks Smiley
James
Fixes: 467
You can change the handset names from the n300 gui. Its settings->handsets IIRC
RealAleMadrid
Aspiring Hero
Fixes: 62
@JamesCRocks  Pleased to see that your number port has gone through OK.
Just checking that you understand that after you deregister the phone handsets from the Panasonic base station it will no longer have any connection to the handsets and they will have lost the names allocated to them. At this point power down the Panasonic base unit as it is no longer required. It appears you are trying to name a handset using the Panasonic #104 command which is not going to work if the handset is no longer connected.
You need to register the handsets to the Gigaset N300IP and set them up using the Gigaset browser based configurator.(GUI)
JamesCRocks
You can, however the names don't appear on the handsets. To be fair, that might simply be a handset problem.
James
JamesCRocks
Yeah, did that but the names don't appear on the handsets and if I use the INTERCOM function, the phone can't see any options.
Ultimately, it's not essential, just a nice to have... my wife, however, might think otherwise.
James
Fixes: 467
I suspect your'e right, its maybe because they are basic GAP handsets. I've only ever used fully compatible Gigaset handsets with my n300 so I can't say for sure.
