Get a FTTP line alongside FTTC line?
fishtank
Re: Get a FTTP line alongside FTTC line?
All right, not going any, umm, deeper into this for now anyway.
And to Rob, hmmm that phrase rings a bell in another capacity which escapes me just now.
thanks all
@fishtank
I asked Gemini AI this "Explain Openreach Full Fibre architecture"
This is the result https://g.co/gemini/share/1bc31d0e21ab
Hope it helps
krusty
gpon Fibre is not daisy chained ..
There is an optical spitter (prism i believe) to feed the download light to the 32 fibres ( a unit of 32 is a pon) and a combiner (probably the same unit) to combine 32 upstream light paths. note typically less than 30 streams are used per pon by bt.
Each fibre in the pon is assigned to a uprn
The fibres are then fed to cbts either underground/overground and recently with micro cbts into mdus and on sides of buildings.
None of this really matters in how your full fibre internet connection works.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Everything Else
198kHz
Fixes: 42
@fishtank wrote:
Which bodes the question, for the less than 50metres to the FTTC cabinet still copper, is that _in _fact_destined to be scrapped or could one live out remaining purely on FTTC - even if the analogue phone goes in 2027
Fibre is available if I wanted it, but 40/10 FTTC is more than adequate. I can't see Openreach being in any hurry to start widescale recovery of the D side (cab to home) cables.
BT technician (Retired)
