Remove ptr from static IP
- Everything else
- Remove ptr from static IP
07-06-2025 2:41 PM
Would it be possible to remove the current ptr from my static IP?
Message 1 of 2
(501 Views)
1 REPLY 1
Re: Remove ptr from static IP
09-06-2025 11:18 AM
Thank you for taking the time to contact us on our Community Forum, I hope you are well.
I have now raised a task to our NetOps team to remove the PTR from your static IP, I have emailed you the task reference number, please allow up to 5 working days for this to be processed.
I hope this helps
Message 2 of 2
(426 Views)
- Everything else
