FTP problems
- Everything else
- Re: FTP problems
FTP problems
03-09-2007 11:09 PM
I'm having trouble logging into my webspace using CuteFTP or SmartFTP
I'm logging into
ftp.plus.net and using my normal plus.net username and password but getting a valiudation failure.
Please help
I'm logging into
Please help
Message 1 of 8
(3,310 Views)
7 REPLIES 7
Re: FTP problems
03-09-2007 11:15 PM
try logging into 212.159.9.131 and use your username and password.
Make sure you only us the first part of your username not user@plus.net
I assume yours is jaythe0ne remember its case sensitive for name and password
Message 2 of 8
(992 Views)
Re: FTP problems
03-09-2007 11:21 PM
Still doesn't work, i've managed to log onto ccgi.jaythe0ne.plus.com using my plus.net username and password, but still can't log onto ftp.plus.net
Message 3 of 8
(992 Views)
Re: FTP problems
03-09-2007 11:26 PM
To get to ftp the address is ftp://username@ftp.plus.net is this what you are using.
Message 4 of 8
(992 Views)
Re: FTP problems
03-09-2007 11:37 PM
its almost as if the webspace doesn't exhist, i've activated Cgi and PHP on my account, i've registered a domain name with PN. I can log onto the CGI server, i just can't ftp my webspace. i keep on getting a validation error.
Message 5 of 8
(992 Views)
Re: FTP problems
04-09-2007 5:18 PM
I know this is probably a daft question. Are you ftping to the Htdocs folder? The ftp address would then be:
ftp://username@ftp.plus.net/htdocs
At least that's how it works on Free-online.
Message 6 of 8
(992 Views)
Re: FTP problems
04-09-2007 8:17 PM
PN answered my ticket, in a speedy fashion i have to say :), they said it was a known issue at the moment that they were haveing password issues, i havbe set a new password and it all works fine now
Message 7 of 8
(992 Views)
Re: FTP problems
05-09-2007 10:56 AM
i have a similar problem.
when using filezilla my first log in atempted works and i can browse to my forum directory, then when i try to browse one folder lower i get disconected
when i reconnect i can browse as far as the 3 teir then get disconnected again
log back in and i can get to the forth tier........
its very frustrating, i spent 20 mins last night just trying to get to the second teir as it kept kicking me so i couldn't upload the files i wanted.
does the ccgi webspace have some manic time out on it? filezilla always says a "time out detected" as the cause of the disconection.
Message 8 of 8
(992 Views)
