cname troubles
- Everything else
- cname troubles
cname troubles
03-09-2007 5:09 PM
I am pretty new to all things domain related so I am hoping I can get some help.
I basically want to create a new CNAME record in my domain management section. (I want to do this in order to verify my domain name for a google service I want to try)
Here is what they say on the google service verification page ...
1. Sign in to your domain hosting service and locate the DNS management page. The location varies by service, but can typically be found under Domain Management or Advanced Settings .
2. Use the following unique string to create a new CNAME record:
googleffffffff95968e81 . giraffeandtiger.co.uk
3. Point the CNAME record to:
google.com
4. Once you have made the changes, you can verify that the record exists by doing a CNAME lookup for http://googleffffffff95968e81.giraffeandtiger.co.uk . You can find several web sites to do automated CNAME lookups by searching for CNAME lookup at http://www.google.com .
I have added a record to my domain name configuration through the member center as follows.
Left field: googleffffffff95968e81.giraffeandtiger.co.uk
Type: cname
Pri: [left this blank]
Right Field: google.com
I have tried using a CNAME lookup tool on the net to determine if this has worked and get 'no entries' reported for googleffffffff95968e81.giraffeandtiger.co.uk, but I do get entries reported for www.giraffeandtiger.co.uk.
Quote Domain Type Class Result
giraffeandtiger.co.uk. NS IN ns2.force9.net.
giraffeandtiger.co.uk. NS IN ns1.force9.net.
ns1.force9.net. A IN 195.166.128.16
ns2.force9.net. A IN 195.166.128.17
I have now also tried adding an additional entry as follows
Left Field: googleffffffff95968e81
The rest is the same as above
Still no joy - I have had these entries set up since Friday now and still not getting any joy from a cname lookup tool - (except for www.giraffeandtiger.co.uk).
Can anyone give me any advice on what I'm doing wrong?
Thanks,
Alan
Re: cname troubles
03-09-2007 5:37 PM
Type: cname
The other thing I'm wondering is should I be waiting longer for these changes to take effect - since you could say it has not yet been 48 hours yet (in working days) since I made the change ...
Alan
Re: cname troubles
03-09-2007 5:40 PM
googleffffffff95968e81.giraffeandtiger.co.uk. 14400 IN CNAME google.com.giraffeandtiger.co.uk.
Which looks like you didn't place the trailing . after google.com in the CNAME record so it has appended the domain to the end again.
I'll go edit this now for you, it will take around 12 hours to update.
Re: cname troubles
03-09-2007 5:46 PM
Thanks very much for all the great assistance. I will hold my breath for the next twelve hours.
I must say I am very impressed by the response time on this forum
Alan
Re: cname troubles
03-09-2007 5:52 PM
Both of the exisiting CNAMES have been removed and I have added
googleffffffff95968e81 CNAME google.com.
I haven't put a trailing . on googleffffffff95968e81 as this will append the domain name on the end now.
Re: cname troubles
03-09-2007 5:58 PM
Should I be able to see anything right now using a cname lookup tool? - such as something like your quote from earlier ...
Quote googleffffffff95968e81.giraffeandtiger.co.uk. 14400 IN CNAME google.com.giraffeandtiger.co.uk.
Because I see
Quote No CNAME records exist for googleffffffff95968e81.giraffeandtiger.co.uk
when I try looking for cname records on googleffffffff95968e81.giraffeandtiger.co.uk
Re: cname troubles
04-09-2007 9:07 AM
Re: cname troubles
04-09-2007 9:23 AM
Thanks for the great support.
Alan
CNAME question
04-09-2007 10:39 AM
Can I use a left field of 'www.example' as a left field in a CNAME entry if I already have an entry using 'www'?
Thanks,
Alan
Re: cname troubles
04-09-2007 1:33 PM
forum CNAME ccgi.plus.net.
It would redirect e.g. http://forum.giraffeandtiger.co.uk to the root of ccgi. In ccgi-root a .htaccess could then point it to a desired directory.
Isn't it a bit unfair that http://googleffffffff95968e81.giraffeandtiger.co.uk is allowed to point to another ISP, but not to the own PlusNet one. ?
Re: cname troubles
04-09-2007 1:48 PM
Left Field: php
Type: CNAME
Right Field: ccgi.giraffeandtiger.plus.com.
When I use my friends domain address http://php.thebazaarofbohemia.org.uk/
I am ending up getting re-directed straight to http://www.plus.net/
A CNAME lookup tool gives me the following response for php.thebazaarofbohemia.org.uk
ns.hosteurope.com. A IN 212.67.202.2
ns2.hosteurope.com. A IN 212.67.203.246
Anyone know how to make this work?
Re: cname troubles
04-09-2007 9:40 PM
www
ccgi
Anything else will be ignored and you redirected to plusnets home page.
You can use any sub-domain if you are running your own webserver (i.e. a webserver running on your adsl line).
Re: cname troubles
05-09-2007 12:24 AM
forum
would be a good sub-domain.
Re: cname troubles
05-09-2007 1:43 AM
Does this mean I can't stick anything in the dns entries of my friends server domain settings to link to my plusnet cgi space?
Or can I do something using ccgi or www?
What would I stick in the right and left fields?
Thanks for all the help 🙂
Alan
Re: cname troubles
05-09-2007 1:51 AM
