FTP access error
kissinuk
FTP access error
I'm getting a 530 Login incorrect error when I try to connect to FTP. I'm using ftp.plus.net with my main user name and password.
Is anyone able to have a look for me please, or is there any web file access I can use instead? It used to work fine but I haven't tried for a long time.
17 REPLIES 17
kissinuk
Re: FTP access error
Hi, is anyone from Plusnet able to help with this please? I did ask the support team on Twitter but they told me it needed to be raised here instead!
Surely I don't need to phone up just to get ftp access to my files?
Champnet
Aspiring Hero
Fixes: 15
Your are just using your username ?  I.E fsmith not fsmith@plus.net or other.
kissinuk
Yep, just using my username. I still have all the settings stored in an ftp application from ages ago. The only change since then is my password.
Looks like there have been similar issues raised on here in the past and someone from PN had to fix.
Champnet
Aspiring Hero
Fixes: 15
If using a windows machine try :
At C:\ prompt type ftp
ftp> enter "open ftp.plus.net"
user enter "your username"
password: enter "your password"
This should make a connection, if not then the pasword is wrong.
If connected the only command I remember is LS to show files. If advenurous ? will list commands...............
kissinuk
Still the same error, it won't accept my account password:
220 Plus.Net FTP Server #1 ready
200 UTF8 set to on
User (ftp.plus.net:(none)): ****
331 Password required for ****
Password:
530 Login incorrect.
Login failed.
Champnet
Aspiring Hero
Fixes: 15
OK, any unusual non-alphanumeric characters in your pasword ?
If not then you need a Plusnet member of staff to help, hopefully a mod will rub their magic lamp...............
kissinuk
Yes, there are indeed a couple of special characters, could that be the cause?
Thanks for the help btw!
Champnet
Aspiring Hero
Fixes: 15
Maybe, try changing it temporarily to something simple.
kissinuk
Looks like the PN password policy enforces a special character anyway, I did simplify but no joy.
If anyone from Plusnet is able to have a look that would be great,
kissinuk
@bobpullen are you able to help with this one please (or know who can)?
MatthewWheeler
Fixes: 501
Hi @kissinuk
I've raised this to our backend team to look into.
As soon as we know more we'll be in touch
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
bobpullen
Fixes: 317
I've kicked some stuff at this side. Try again later today/this evening and see if you've any more luck.
kissinuk
Thanks for trying Bob, unfortunately it still isn't working. Are there any restrictions on password length or characters for the password? I'm definitely using the right password and I've used by username on it's own.
Status: Resolving address of ftp.plus.net
Status: Connecting to 212.159.9.91:21...
Status: Connection established, waiting for welcome message...
Status: Insecure server, it does not support FTP over TLS.
Command: USER ****
Response: 331 Password required for ****
Command: PASS ****
Response: 530 Login incorrect.
Error: Critical error: Could not connect to server
bobpullen
Fixes: 317
Is/was there anything uploaded to your webspace that you're bothered about, or could we start from scratch?
