Would like to transfer 2 domains from PlusNet to Cloudflare
TimDSMoss
I called the customer support line on 02/10 asking to transfer my domains
and supplied the IPS Tag CLOUDFLARE
They then raised a request with NetOps(?) on the morning of 03/10
However, nothing has happened.
I waited the expected 24-48 hours and called back on two further occasions
Both operatives were as helpful as possible
but told me that only the person who I originally spoke to could give me an update,
they said they would message the person I originally spoke to asking them to send me an update
I've not yet heard anything
- I'm not sure if there was an issue, or it just hasn't been actioned yet, more info needed from me or what.
There's some config and DNS record changes I need to carry out once the transfer has happened so would be really useful to know when (or if!) it may happen
Is there anyone here that can help?
e.g. @willcutforth
Thanks in advance
Tim
5 REPLIES 5
willcutforth
Fixes: 113
Re: Would like to transfer 2 domains from PlusNet to Cloudflare
@TimDSMoss it was raised incorrectly last time so I have raised it now for you. SOrry about this.
 Will Cutforth
TimDSMoss
Many thanks WIll - most appreciated
willcutforth
Fixes: 113
It should all be sorted now for you Smiley
 Will Cutforth
TimDSMoss
All resolved now - many thanks for your help WIll
Penny
Fixes: 9
... @TimDSMoss
Afaik the 'fix' (ie the 'fixed' credit on a forum thread) is usually given to the person who (or whose post) sorted the problem, rather than the original poster (?)
Might have thought @willcutforth was entitled to be credited for this one.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
