Changing my Reverse DNS please
skdj
I would like to have my reverse DNS changed from user.plus.com to www2.domain.co.uk please
7 REPLIES 7
skdj
Re: Changing my Reverse DNS please
I googled and found losts of posts here asking for a change to their PTR record/ reverse DNS from userName.plus.com to sub.domain style so I thought I would post here looking for action.  if there is another way to go about getting plus.net employees attention I'll listen.
Fixes: 585
@skdj posting on here is the normal way to get rDNS changed. It may take a day or so for staff to pick up this thread. They will then raise a ticket for you to confirm the rDNS setting and will then raise a task to NetOPS. In the mean time you will need to ensure there is a corresponding 'A' record on your domain DNS  pointing to your static IP.
skdj
How long would this typically take?
Fixes: 585
Depends on staff presence on the forum and they are a bit thin on the ground just at the moment. If its not picked up in the next couple of days, post back , tag me and I'll escalate it.
skdj
still hasn't been picked up by staff.
Tags (1)
Fixes: 251
@James_B
Ditto new team awareness... please.
Peter_JW
Hey there @skdj.
I've just sent you over a private message so we can get this checked out.
Peter
