parental controls
bradders100
parental controls
i want to block certain websites via my plusnet account but i converted from my original plusnet router to a deco mesh. will this affect the controls that plusnet can enforce?
3 REPLIES 3
Fixes: 1,495
Re: parental controls
Moderators Note
This topic has been moved from Broadband to Everything Else
Fixes: 1,495
Once you have enabled safeguard in the portal, you will need to update the DNS servers in your Deco system to the safeguard ones found here https://www.plus.net/help/broadband/about-dns-server-and-website-settings/
There are also other options like NextDNS and OpenDNS to achieve the same things.
Fixes: 251
@dvorak
Whatever the router, if it is configured to "Get settings from the ISP" will not that deliver the correct IP addresses?
