Change of IPSTAG request
Peter39
I am moving my email provision to another provider. I have a domain hosted by PlusNet but unfortunately because you don't permit the addition of TXT records (or those for DKIM) I must move the hosting. Please can someone arrange to have the IPSTAG for my domain changed?
9 REPLIES 9
Fixes: 244
Re: Change of IPSTAG request
If you post the new ISPtag here @plusnettony might be able to pick up the request for you.
Fixes: 475
Moderator's note:
Thread moved from Broadband to Everything Else
Peter39
Thanks. The new IPSTAG should be MYTHIC-BEASTS
plusnettony
Fixes: 64
For security and accountability reasons, I've created a ticket on your account - 255849968. Please log into the portal and reply to that ticket confirming the domain and tag and I'll action it when I see the ticket. Thanks.
 Tony T
Fixes: 244
Excellent choice!
If on logging into the portal, there is not an obvious link to the ticket (see the messages "bell") then use the link below.
kingjp
How do I change my IPS TAG on my domain which is currently registered on my old MADASAFISH account?
Fixes: 577
@kingjp you post here and hopefully a staff memeber will pick it up and raise a ticket for you to provide the details. You are probably best starting your own thread though.
You could try calling support but the chances of getting someone who understands what you are asking for is slim I'm afraid
Fixes: 577
@kingjp I've tagged a staff member on another thread. Give it a while to see if they reply before creating your own thread
Christopher_G
Hi @kingjp
I've sent you a private message. Could you take a look and reply to me through your community inbox please?
Chris
