IPS TAG request
Slapdash2
IPS TAG request
Hello, I would like to move my domain, that is currently registered with Plusnet, to Mythic Beasts which I believe will require a change of IPS TAG. I was told that the IPS TAG has to be specifically include MYTHIC-BEASTS in upper case. If you can, please PM me, I can provide the nameservers and a backup Gmail email address in case there are any problems and you need to contact me. Thanks for your help.
3 REPLIES 3
Christopher_G
Fixes: 5
Re: IPS TAG request
Hi @Slapdash2
I've sent you a private message to get a little more information from you. Could you take a look and get back to me please?
Chris
Fixes: 585
Re: IPS TAG request
@Christopher_G
while you're here...😁
There's another new request here https://community.plus.net/t5/Everything-else/Change-of-IPSTAG-request/m-p/2056847#M42182 on an existing thread
Christopher_G
Fixes: 5
Re: IPS TAG request
Got it, thanks @MisterW Smiley
