Can't enable static IP
peter_lavelle
Sorry if I should have posted this to an existing thread instead.
My Broadband service was activated yesterday but when I try to activate the static IP address in my account via the portal, it doesn't seem to work.
Likely something I'm doing wrong. Have rebooted my router since everything was setup, but had no joy.
Tags (1)
2 REPLIES 2
Fixes: 586
Re: Can't enable static IP
Actually it probably isn't!. The automated static IP activation doesnt seem to work on some accounts.
Im sure a staff member will be along shortly to process it manually.
MatthewWheeler
Fixes: 503
Hi @peter_lavelle
That should be sorted for you now.
If you reboot your router you should pick it up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
