Can't enable static IP
- Everything else
- Re: Can't enable static IP
08-02-2024 3:53 PM
Sorry if I should have posted this to an existing thread instead.
My Broadband service was activated yesterday but when I try to activate the static IP address in my account via the portal, it doesn't seem to work.
Likely something I'm doing wrong. Have rebooted my router since everything was setup, but had no joy.
Message 1 of 3
(1,082 Views)
2 REPLIES 2
08-02-2024 4:19 PM
Actually it probably isn't!. The automated static IP activation doesnt seem to work on some accounts.
Im sure a staff member will be along shortly to process it manually.
Message 2 of 3
(1,072 Views)
10-02-2024 12:30 PM
That should be sorted for you now.
If you reboot your router you should pick it up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
- Everything else
