Can I Install Wordpress In My Free Webspace
- Everything else
- Re: Can I Install Wordpress In My Free Webspace
26-06-2009 7:48 AM
I am uncertain/confused that they even meet the minimum requirements;
- PHP 4.3 or greater
- MySQL 4.0 or greater
- The mod_rewrite Apache module
Can anyone please advise me?
Regards, red
29-06-2009 7:17 AM
http://usertools.plus.net/tutorials/id/57
I will update this post as soon as I have been able to get it to work.
Regards, red
29-06-2009 3:00 PM
Maurice
30-06-2009 7:30 AM
- for DB_NAME I used the databse set up for me by Plusnet
- for MySQL database username I used my Plusnet username
- for MySQL database password I used the password provided (by Plusnet email) when MySQL was activated
- for MySQL hostname I used the web address for my blog http://www.username.plus.net/blog
Are these settings correct? Are there more settings I need to change?
I am not convinced they are and I have not had time to play around with the settings yet.
Incidentally in MySQL under Create new database: Documentation it shows No Privileges; is this correct?
Can you please give me some advice on what the settings should be?
Best Regards, red
30-06-2009 10:15 AM
30-06-2009 10:27 AM
Regarding the Create new database: Documentation it shows No Privileges; is this correct?
Would I be better to create a new database for my blog or use the default provided by Plusnet?
Best Regards, red
30-06-2009 4:52 PM
You won't have permission to create your own database, so you'll need to use the one created for you, which will contain your username and either _pn, _f9 or _fol depending on the vISP you signed up with. Again this is in your activation email.
HTH.
30-06-2009 9:33 PM
This prefix is added to all table names used by the application (in your case wordpress) and allows you to have multiple applications using the same database, without risk of having the same table name.
06-07-2009 7:39 AM
The only thing I would now like to do is rather than use http://ccgi.username.plus.com/blog i would like to be able to use the address http://www.username.plus.com/blog (or even http://www.username.plus.com). Is this possible?
Regards, red
07-07-2009 11:25 AM
- Everything else
