help required on dns settings to point my domain at google sites
- Everything else
- help required on dns settings to point my domain a...
03-07-2009 10:28 AM
Hello,
I'm after some help on what to set my dns settings to get my domain pointing to google sites.
The instructions on google sites say ...
I've found this support page on plusnet help and support ...
http://www.plus.net/support/domains_and_dns/hosting/domain_admin_dns.shtml
Does this mean I create a CNAME record with the following?
Left field: somborneplayers.org.uk
Type: CNAME
Pri: (leave it blank)
Right Field: ghs.google.com.
The plusnet support page also says I need to create an additional A record for every CNAME alias that I make. Is that the case here? What should I put in the A record fields if so?
Any advice would be appreciated
Alan
- Sign in to your domain registrar.
- Navigate to your DNS Management page. The location and name of this page will vary by host but can generally be found in Domain Management or Advanced Settings.
- Find the CNAME settings and enter the following as the CNAME value or alias: (your sub domain)
- Set the CNAME destination to the following address: ghs.google.com
- Save changes with your domain host
Type: CNAME
Alan
Message 1 of 7
(2,971 Views)
6 REPLIES 6
Re: help required on dns settings to point my domain at google sites
03-07-2009 6:15 PM
You can't create a cname using the root record only. You have to use a sub domain i.e www.somborneplayers.org.uk. If you want somborneplayers.org.uk to point to ghs.google.com this can be done by the use of http redirection but not sure if PN support this.
So you will enter
Left field: www
Type: CNAME
So you will enter
Left field: www
Type: CNAME
Message 2 of 7
(347 Views)
03-07-2009 6:23 PM
Quote from: giraffeandtiger
An A record have to exist for the CNAME you only have to create an A record if you have created the domain/sub domain. As an A record already exist for ghs.google.com you only need to generate the cname record.
Message 3 of 7
(347 Views)
07-07-2009 10:43 AM
Quote So you will enter
Left field: www
Type: CNAME
That worked a treat!
Quote not sure if PN support this
Looks like they do
Message 4 of 7
(347 Views)
07-07-2009 11:15 AM
I was referring to PN not supporting http redirection, this differ from cname.
Message 5 of 7
(347 Views)
07-07-2009 11:19 AM
Ah - ok
The important thing to me is that now when I put www.somborneplayers.org.uk into the address bar it brings up the page I want. Thank you for that
Message 6 of 7
(347 Views)
07-07-2009 11:26 AM
I just re-read your message and have now realised what you were trying to tell me. That a root record is the address without the www?
Google have said this about their site mapping anyway
Quote Mappings are restricted to sub-domain level only like www.example.com, wiki.example.com or support.example.com. We don't support naked domain mapping such as example.com.
Message 7 of 7
(347 Views)
- Everything else
