Bulk Migration
dws1900
Bulk Migration
Hi
Can PlusNet initiate a  Bulk Migration process?
11 REPLIES 11
EmilyD
Fixes: 117
Re: Bulk Migration
Hi @dws1900,
I don't quite understand the question, I'm afraid. Please can you provide some more information?
 Emily D
dws1900
Re: Bulk Migration
@EmilyD
I have been speaking to an engineer  regarding the incorrect provisioning of my line, and others in my street.
It was suggested that a Bulk Migration of the lines from the incorrect dslam to the correct one would be away to go,
and it may be something an ISP would initiate.
It was also suggested that two different dslams onto the same bearer cable (ie 100 pairs cable) is not a good idea due the interference/cross-talk issues that would arise.
EmilyD
Fixes: 117
Re: Bulk Migration
Thank you for providing those further details @dws1900. This isn't something that we'd be able to initiate from here, I'm afraid.
I've tested your line but the test isn't picking up any problems from here at the moment and indicates that your line is currently syncing at 22.3mbps, which is within the estimates. Please let us know if the speed that you're seeing on your side is significantly lower than this or if you're experiencing any other connection problems at the moment.
 Emily D
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Bulk Migration
@EmilyD  I don't think you quite understand what @dws1900 is getting at. There are a number of lines in the vicinity that would get much higher speeds if they were moved to a nearer cabinet which Openreach have so far failed to action. I agree that it is something that PlusNet cannot request because several different ISPs may be involved, but attempting to get any sense out of openreach is very difficult. Your test of the Op's current line speed is totally irrelevant.☹️
ejs
Aspiring Hero
Fixes: 25
Re: Bulk Migration
It's not clear from the context if the term "bulk migration" was supposed to refer to some specific process or if it was merely a descriptive term for moving all the lines from one cabinet to another in one go.
Openreach have something they call a "live to live migration" for when Openreach decide to move a line from one cabinet to another. I don't see why an ISP would have to request it. Openreach can do pretty much what they like to their network when they like.
dws1900
Re: Bulk Migration
@ejs
I would suggest the term Bulk Migration in this context is a process to carry out a physical action to move numerous lines from one dslam to another dslam, within the duration of the job.
I am only relating what the engineer told me, and a possible course of action.
ejs
Aspiring Hero
Fixes: 25
Re: Bulk Migration
Yes, and thinking about it logically, I see no reason for an ISP to have any involvement in how Openreach wire up their network.
The trouble is I'm pretty sure bulk migrations can refer to something completely different, typically moving people from one product to another, which may involve no physical wiring changes at all.
dws1900
Re: Bulk Migration
@ejs
The term 'Bulk Migration' may well refer to many things, but in this context it related to the moving of a number of circuits onto the correct dslam. Contacting OR as a consumer does not work.
Fixes: 1,484
Re: Bulk Migration
Moderators Note
This topic has been moved from Fibre to Everything Else
dws1900
Re: Bulk Migration
@dvorak
Why move this thread?, its to do with fibre broadband.
Fixes: 1,484
Re: Bulk Migration
Because you're raising a question outside of an issue with a single users fibre connection - that board is for: "Problem with your Fibre connection? Let's see if we can help. "
