BT Wholesale Speed Test
outcast
Aspiring Champion
Fixes: 19
Re: BT Wholesale Speed Test
@Dan_the_Van wrote:
I think ... ... the Additional Diagnostics have not functioned for a very long time
The last time I used BTW "Additional Diagnostic" was a few days before Christmas 2024, to check that my broadband was at full speed and ready for holiday gaming and streaming.  Unfortunately that time I didn't bother recording a screenshot, as the test result was fine.
The last record I have was taken after I'd done a network tune-up and had just fitted a new modem on 30th October 2024 -
goldenfibre
Seasoned Pro
Fixes: 12
I find other BTW speedtester and it run successfully and ask for Further Diagnostics and come back say IP Profile for your line is 77.35Mbps as I was on SoGEA 80/20
outcast
Aspiring Champion
Fixes: 19
Re: FTTP Speedtest Issue
@goldenfibre wrote:
Was told by my ex ISP that BTw will put IP Profile via control panel ...
... Not sure if ... Plusnet will added it ...
@goldenfibre   What are you on about ?
Plusnet have effectively had the "IP Profile" displayed in the "Member Centre" for years as "Current Line Speed" !
"Current Line Speed" = BTW "IP Profile" rounded down to nearest 0.1Mbps, then has 0.1Mbps subtracted,
as the ideal ISP profile should be about 100Kbps slower than the BTW profile, to maximise speed and minimise packet loss
goldenfibre
Seasoned Pro
Fixes: 12
I must have spoken too soon. BTW Speedtester now gone off!
Fixes: 387
You did - it no longer exists.
outcast
Aspiring Champion
Fixes: 19
@goldenfibre  what URL are you using to get that ?
goldenfibre
Seasoned Pro
Fixes: 12
@outcast Not working now. Pointless now.
outcast
Aspiring Champion
Fixes: 19
You're wrong, it's working for me !
Look at the time and date in the top right of this screenshot -
Mav
Fixes: 518
@outcast
Did you actually pass 'Go'?
Forum Moderator and Customer
outcast
Aspiring Champion
Fixes: 19
@goldenfibre wrote:
... BTW speedtester ... say IP Profile for your line is 77.35Mbps as I was on SoGEA 80/20
No, not because you were on SoGEA, but that your line to the FTTC cabinet is so short (to have previously been getting such high speeds on G.Fast), that your router's VDSL download path isn't interleaved,  whereas my screenshot is of a modem with an interleaver depth of 8 and resulting in my profile being lower at 74.11Mbps,  despite our modem download sync speeds probably both being at 80.0Mbps.
outcast
Aspiring Champion
Fixes: 19
@Mav wrote:
@outcast
I didn't bother pushing 'GO' as it's been hanging on the next screen for about 12 days now,
but that wasn't the point of my screenshot, I was just showing that I don't see the 404 screen that @goldenfibre posted.
[edit] just for completeness pressing 'GO' shows this -
goldenfibre
Seasoned Pro
Fixes: 12
working again see time at bottom right corner
goldenfibre
"Not many peoples can't be bother to logged into 192.168.1.254 with username and password."
Is that a use of the double-negative (few people can be bothered...) ?
Not all Hub2s will be 192.168.1.254. They may have when they are left with default configurations.
outcast
Aspiring Champion
Fixes: 19
@goldenfibre  yes you're right ! - see time and date on my Additional Diagnostic results page ! -
goldenfibre
Seasoned Pro
Fixes: 12
@outcast your BTw tester are FAKE (ip profile cannot be the same as your throughput speed)
