Change to fibre
Tinacorr7
Change to fibre
If I change to fibre will I need a new hub etc?
7 REPLIES 7
Fixes: 357
Re: Change to fibre
@Tinacorr7 Which Hub do you currently have, and which Full Fibre speed are you looking at?
Tinacorr7
Re: Change to fibre
I have the standard hub with phone line
Fixes: 357
Re: Change to fibre
Hub1 or Hub2? And you are aware you will lose the phone if you switch - which you will do in the next 18 months or so anyway?
Tinacorr7
Re: Change to fibre
Yes thanks. Don’t know the hub but my contract is unlimited fibre extra plus line rental
Fixes: 357
Re: Change to fibre
Not a big problem - as far as I know, the Hub1 can handle the lower speed tiers, but the Hub2 is better all round. For information, the H1 has its lights at the bottom, the H2 has them in the centre 'front'.
Fixes: 105
Re: Change to fibre
@Tinacorr7
You can check here which router you have.
https://www.plus.net/help/broadband/router-setup-guides/
If you have a Hub1 you'll be offered a Hub2 for £6.99 postage and packing.
Fixes: 1,491
Re: Change to fibre
Moderators Note
This topic has been moved from Full Fibre to Everything Else
