greenby migration woes
handfordjeffes
If been with F9/Plusnet for over 30 years, one account changed over without me even noticing but then 2 more accounts only work on the Greenby page, I have 14 accounts for various local clubs and non-profit groups, this morning only 2 have incoming email and one of those can't sent email anymore.
This is a joke I only found out I had been migrated when i managed to logon to the greenby site and see my welcome email. I have raise numberous tickets on there but only get AI responses they do say I need a person and would I like to wait, I say I do and nothing!
I spoke to Plusnet they said basically we passed over to greenby, not our problem, I said you live off of your reputions of customer servise why would I get my phone/broardband from you after this? I have friends who say they are moving after this and have already set up Gmail accounts as it's too much hassle to login on the greenby site to check to see if they have email or send email or read an email you had the other day!
What answers have greenby come up with, my account could be sleeping and my come back in a few days, 2 weeks later that's wearing thin. What can I do enter my username in agian on thunderbird even though it's been working for years. And what happens when I do that no change that account or password is not working, but the same name and password works withing greenby.
Anyone else had this I've checked the account that works and the ones that don't and all the settings except the username are the same, nothings changed except greenby is hosting it?
26 REPLIES 26
Fixes: 577
Re: greenby migration woes
@handfordjeffes taking the email address structure for force9 as <mailboxname>@<username>.f9.co.uk, so we can try and help understand the problem
do you actually mean 14 accounts i.e different usernames ?
or 14 mailboxes i.e different mailboxnames with the same username ?
handfordjeffes
No I have 14 or more accounts as in usernames with either plusnet or force9 going back to the 1990s.
Some work now and some don't, I only know the working ones if I get the welcome email which has come once so far. None of my plusnet account have migrated yet only some of the f9 ones.
Fixes: 577
Ah!
First no <username>.plus.com accounts have migrated so they should still work exactly as before.
For the force9 ones, the migration is still in progress. You SHOULD have received an email to the contact address (probably <username>@<username>.f9.co.uk ) for any account that has migrated.
If you have an active PLusnet broadband account, then ONE of the force9 mail accounts should be free for 2 yrs but the others will be subject to a £15/yr charge after the 1st 30 days.
If the account has been migrated , then you should be able to login to the Greenby portal https://greenby.com/ using the force9 username and password and selecting force9 as the provider
handfordjeffes
Yeah if I go one Greenby.com and login I can see my welcome email, but cannot get it through thunderbird last email I had was 20th of Nov!
Not sure about the Plusnet I've recieved email for plusnet account this morning but if I try to send I get
Sending of the message failed.
An error occurred while sending mail. The mail server responded: Unknown sender. Please verify that your email address is correct in your account settings and try again.
which i think i may have had before the f9 ones changed over.
Fixes: 577
Are you using the email address or account+mailbox as the username to authenticate the account in thunderbird ?
Is the sending email address a real mailbox or are you using an alias ?
The PLusnet mail server is alias agnostic i.e will accept <anything>@<username>.plus.com providing the username part is correct but currently the Greenby server will only accept real mailbox names as email addresses.
If that's not the cause, then post all the information for the SMTP error as there should be more details
handfordjeffes
just my email address [email protected]
I'm using
Server type: POP Mail Server           Port 110
Server name: mail.force9.net
Username: USERNAME (see below for change)
Outgoing server username - relay.force9.net
Update I just had a reply saying to change my username in Thunderbird from USERNAME to USERNAME@<yourusername>.f9.co.uk and you actually type "<yourusername>" this confused me I type in my USERNAME and it did nothing so I thought I'd type in <yourusername> as written here and it did something, it downloaded 5 emails ending with the welcome to greenby but nothing after that so 02:12:2025 on one account and  24:11:2025 on the other .
Fixes: 577
The email address format for f9/force9 mailboxes is <mailbox>@<username>.f9.co.uk.
The primary mailbox is <username>@<username>.f9.co.uk and secondary mailboxes are <somethingelse>@<username>.f9.co.uk.
So using the example of username being bloggs, the primary mailbox would be [email protected] and a secondary one would be [email protected].
A mail client such as Thunderbird needs a username & password to authenicate with the mail server to access a particular mailbox. The username historically has been either the full email address for the mailbox OR <username>+<mailbox>. It seems at the moment that the full email address doesnt work for secondary mailboxes and the 2nd format should be used.
Using just <username> will access the primary mailbox. To access a secondary mailbox it needs to be <username>+<mailbox>
So using my example above the username bloggs would access the primary mailbox whereas bloggs+joe would access the joe mailbox.
@handfordjeffes In your case it would seem that [email protected] is a secondary mailbox, so thunderbird will need the username+mailbox format (note the '+' character is needed)
Note also, that the password for the primary & secondary mailboxes can be different, if you are unsure then reset the password for the secondary mailboxes using the Greenby portal
Fixes: 146
@handfordjeffes
when you say me@<username>.f9.co.uk, does me have a full stop?
So the email address is something like  handford.jeffes@<username>.f9.co.uk
handfordjeffes
Just a name no . I have an update from Greenby
The issue is that your username needs to be the full email address rather than just the mailbox name.
To get your email client working correctly, please remove the existing account first (and take a backup if you are using POP3), then re-add it using the settings below:
Use Username and Password Authentication – No SSL/Encryption
Incoming (IMAP)
Server: imap.force9.net
Port: 143
Username: full email address
Password: email account password
Incoming (POP3)
Server: mail.force9.net
Port: 110
Outgoing (SMTP)
Server: relay.force9.net
Port: 25
Please try re-adding the accounts using these exact settings. Let us know if you run into any issues — we’re happy to help.
So I changed  User Name to [email protected] and on one account it worked I did end up with copies of the last month of emails but that was easy enough to delete them.
But my other account did nothing other than asking for my password and then saying
Login to server mail.force9.net with username [email protected] failed.
Strange thing is an another account that changed over weeks ago works and is just the username  for User Name instead of the full email address. So when this works, if it works, I may end up with 3 different User Name formats?
handfordjeffes
Incoming (IMAP)
Port: 143
Incoming (POP3)
Port: 110
Outgoing (SMTP)
Port: 25
So I changed  User Name to [email protected] and on one account it worked, I did end up with copies of the last month of emails but that was easy enough to delete them.
Login to server mail.force9.net with username <redacted>@<redacted>.f9.co.uk failed.
Strange thing is another account that changed over weeks ago works and is just the username  for User Name instead of the full email address. So when this works, if it works, I may end up with 3 different User Name formats?
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
handfordjeffes
Thanks Everyone I found the fix, at last!!!!
When I was reading my emails on the greenby page I noticed they have a different name in front the @for me at the top ledthand on the window, so I quickly went back to thunderbird and changed the [email protected] to (greeby)[email protected] and 65 emails instantly arrived. Never once in any emails or in Tickets have they mentioned this other name, but it works so if anyone else has this problem. I found if you go to settings, Identity you change it so i have back to my name and will have to see if thunderbird still works or if I have to change the Thunderbird username to my new Identity?
Just tried, that's weird it still works but now I have a different username in thunderbird than I do in Greenby so that name must be hidden deeper, I will have to see if changing in to my new Greenby ID works?
No that doesn't work I've changed it back to the ID greenby had and it works so I guess even though none of my mail is address to that it must be the catchall default I'll have to see if there is such a thing anyway anyone with a problem check on greenby and if they have a different email use that it work for me.
RealAleMadrid
Fixes: 68
@handfordjeffes  Do you know that the email port and security settings in your  msg #11 are totally incorrect?
RealAleMadrid
Fixes: 68
@handfordjeffes Please ignore my previous post. On further inspection some of your settings may be OK but I believe Greenby's suggested settings may not be correct. I don't use any Plusnet email services myself so am not able to offer any advice on the recommended settings.
Catbar1
Hello.
As at Weds 21 Jan'26 - Has anyone experienced the following?
Greenby has not, so far, replied to any of my Tickets.
The first Ticket I created was about 15 days ago (see attachment, which is a screenshot from 2 days ago).
I use Thunderbird and my OS is Desktop Windows 11.
Tags (1)
