Thunderbird password
carldrakes
I have reinstalled win 11 and thunderbird but cannot seem to get the password to work.  I think i need to reset the password, any help appreciated.
T
10 REPLIES 10
Fixes: 381
Re: Thunderbird password
Thunderbird does not have a password as such - your email account does, though = is that what you are talking about?
carldrakes
Yep but I can't remember it!
Fixes: 381
I always keep a written record of important information. Sorry, it is literally years since I messed with my email settings. I'm sure there is a way to reset the password, but I don't recall how.
@MisterW   - can you advise?
carldrakes
Yep I cloned my last two pc swaps and can't remember what it was, have all my others recorded elsewhere, just this one missing!  Doh
Fixes: 1,495
This page https://www.plus.net/manage_my_mail
should take you to manage your mailboxes
if not it's portal > manage account > manage my mailboxes, at the bottom
carldrakes
Cheers but still can't see where to change or find password!
T
Fixes: 1,495
You need to click edit on the mailbox you want to change the password for and then you should be presented with the option to change it.
carldrakes
I managed to change it but don't know how!
Many thank all.
T
carldrakes
Nope for some reason did send a message to my Hotmail account but wouldn't receive anything.  Plugged my old pc in and it works with all the same settings!!
T
carldrakes
AAArrgh just replaced profile folder with older one, now received messages but give error message when sending.  I give up.
Thanks for you help though fellas
T
