Static IP SPF fail
offtrolley
Static IP SPF fail
I have added my static IP address to SPF on my domain name. However, when I view the email header that is sent it shows a different IP address and the email ends up in the spam folder.
Do I have to add relay.plus.net to the SPF for it to work and remove my static IP address ?
20 REPLIES 20
Fixes: 585
Re: Static IP SPF fail
If you're sending via relay.plus.net then you need to add
include:_spf-internal.plus.net include:_spf-internal2.plus.net
To your spf record
Teece
Your e-mail is likely to be marked as spam if you try to send direct - you should always be using the PN smart host, and therefore the pattern above is all you need in your SPF entry.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Email
Fixes: 480
To your spf record
I have been looking at my domain and note this TXT entry from years back:
v=spf1 +a +mx +include:madasafish.com ~all
1. Is this now out of date?
2. Should your advice above be entered as two separate entries?
3. Does it need to be preceded with v=spf1 +a +mx + as per the original? I.e. v=spf1 +a +mx +include:_spf-intenal .plus.net
Fixes: 585
1. Is this now out of date? I beleive so but AFAIK it will still work
2. Should your advice above be entered as two separate entries? You can only have one SPF record so no
Yes , a typical record would be :- v=spf1 a mx include:_spf-intenal .plus.net include:_spf-intenal2 .plus.net ~all
Note mx really only needed if you running your own mail server
Fixes: 480
@MisterW
Thanks. I currently have two records:
I currently send emails through the Plusnet SMPT server and download them from my domain email platform, Namesco (a.k.a hosts). Do I need to delete both records and just add the Plusnet one?
Is there an easy way of checking whether I have an active SPF record.
Fixes: 585
I didnt think you could have > 1 SPF record
The spf record only relates to sending mail. So if you ONLY send via the plusnet relay , then you just need the spf record to define that. My example above should be fine.
Is there an easy way of checking whether I have an active SPF record.  https://mxtoolbox.com/spf.aspx
Fixes: 480
@MisterW
I reckon that you are correct. I get:
I'm a bit chicken about changing things as I currently have no problems. Presumably I am just getting away with it at present.
pjmarsh
Fixes: 24
I suspect you may be getting away with it at the moment by it having no affect.  I think most mail servers would probably error on finding multiple records, and so ignore all SPF checks, so having multiple may in effect be the same as having none.
Fixes: 480
@MisterW
I've bit the bullet and made the changes. it takes 24/48 hrs allegedly for the changes to go through. Fingers are crossed.
Fixes: 585
If you do have two separate SPF TXT record entries, your emails will fail SPF authentication and return a PermError.
@Baldrick1 you really need to fix it.
If you wish to cover all bases then a single record of
v=spf1 a mx include:_spf-internal .plus.net include:_spf-internal2 .plus.net include:spf.hosts.co.uk ~all
should do it
edit: i see you have bitten the bullet
oops , actually Ive just noticed there was typos in my previous post intenal should read internal ( see above )
Fixes: 480
@MisterW
Mark 2 now saved!
Edit
Make that Mark 3.
I wonder if the lot will get updated in 24/48 hours or whether I am now on 3-9 days? We shall see!
Teece
The 12/24 hour thing is a bit spurious. If you have a short TTL on your DNS entry, then it will stop DNS servers using any cached value for this, and getting a 'fresh' copy from your nameservers. I suggest a TTL of 3600 is suitable for most records, which means you'll only need to wait an hour until any changes are recognised.
Fixes: 585
For info , the old madasfish.com spf decodes as a nested include of
internal.madasafish
internal2.madasafish.com
external.madasafish.com
which in turn contain the IP ranges for the various servers.
I believe there's some limit on the number of includes requiring DNS lookup in an spf record ( 8 comes to mind! )
Hence why its probably better to use the internal.plus.net ones since they directly contain the IP ranges and are not nested, so you can be certain how many DNS lookups are present in your SPF
