Salvage deleted emails
Rosalee
In a bid to reduce Plusnet mailbox sizes, I have accidentally deleted all the emails on the Plusnet Webmail server for the email address starting da....(in the last three hours)
Is there any way of salvaging these or are they already lost forever?
9 REPLIES 9
Fixes: 479
Re: Salvage deleted emails
Moderator's note:
Duplicate post removed.
Fixes: 479
@Rosalee
Have you checked that you haven't just moved them to the deleted items folder?
Fixes: 250
@Baldrick1
The usual action of webmail would indeed be for emails to be moved to the trash folder.  Unfortunately the new webmail platform has empty the trash folder on exit set!!  That is different to the way things were before.
@Marsh  / @LexLex2020  / @Windings  @Tina11192  - given the different working of the new webmail service, is there any chance of getting NetOps to do an emergency restore please for this user … as the usual emergency net has been removed.
Fixes: 385
@Townman Should there be a warning about this change? Doesn't bother me, but there a lot of users that only use webmail who may fall foul of this variation in settings?
pvmb
Champion
Fixes: 15
...This is indeed concerning - sometimes one can accidentally delete a post without intending to and only notice at a later time. By 'new webmail platform' is the Greenby service meant?
Fixes: 385
By 'new email platform' is the Greenby service meant?
Yes.
Fixes: 250
The perception that the setting has changed has been raised to the business.
LexLex2020
Fixes: 12
Hi all,
I will raise a request to our net ops team to see if this is something they can do given the circumstances.
I will update once I have a response, usually within about 5 working days.
Leaving this here for me: REQ00916548
Typically, as I am sure you know, this is not something they usually do, will update soon though!
Thanks,
Lex
Lex Keehner
Fixes: 479
@LexLex2020
Whilst you're at it, here's another: https://community.plus.net/t5/Email/Archived-mailbox-Request-for-it-to-be-unarchived-here-Part-2/m-p...
