SMTP feed and Greeny migration
Lorian
Somehow been oblivious to this migration until one of my referees has had issues. I see an initial email about the transfer in my default inbox (not sent to my account email)
I have a domain name hosted only at PN and take an SMTP feed into my own mail server. I send emails using relay.plus.net from several sender addresses (family accounts).
Will I need to make any email changes? Other than maybe my SPF settings on the domain?
9 REPLIES 9
Lorian
Re: SMTP feed and Greeny migration
And I see I'll need to change the name servers for my domains to some greenly servers post migration
plusnettony
Fixes: 62
If the domain is not hosted with us, (ns1.force9.net), you'll be able to change this later.
Other than that, continue to use relay.force9.net.
 Tony T
Lorian
It's registered at 123 but you are doing dns
Fixes: 577
@Lorian I'm not sure that SMTP delivery to your own mail server will still be an option when migrated to Greenby ?
Maybe @plusnettony  can advise...
plusnettony
Fixes: 62
Communication about mail servers went out a few months since. It won't be possible I'm afraid.
 Tony T
Lorian
It won't be still possible to take an SMTP feed to my own mail server?
I've been running that since the Plusnet double email debacle in 2007
plusnettony
Fixes: 62
Let me clarify that - if you use you're own domain, you should be ok.
On Plus.com, no.
 Tony T
Lorian
Phew. Yes own domain, thanks
Any way I can find out which day I'm being transferred so I can check what's happening?
Also I'll need to find and register my account as supporting a vulnerable person as this email deliveries their chemo and oncology appointments
plusnettony
Fixes: 62
I don't as yet.
When you transfer, you can register as vulnerable on the Greenby portal. I can also make changes our side if you want to PM me.
 Tony T
