SMTP feed and Greeny migration
Lorian
Somehow been oblivious to this migration until one of my referees has had issues. I see an initial email about the transfer in my default inbox (not sent to my account email)
I have a domain name hosted only at PN and take an SMTP feed into my own mail server. I send emails using relay.plus.net from several sender addresses (family accounts).
Will I need to make any email changes? Other than maybe my SPF settings on the domain?
18 REPLIES 18
Lorian
Re: SMTP feed and Greeny migration
And I see I'll need to change the name servers for my domains to some greenly servers post migration
plusnettony
Fixes: 73
If the domain is not hosted with us, (ns1.force9.net), you'll be able to change this later.
Other than that, continue to use relay.force9.net.
 Tony T
Lorian
It's registered at 123 but you are doing dns
Fixes: 580
@Lorian I'm not sure that SMTP delivery to your own mail server will still be an option when migrated to Greenby ?
Maybe @plusnettony  can advise...
plusnettony
Fixes: 73
Communication about mail servers went out a few months since. It won't be possible I'm afraid.
 Tony T
Lorian
It won't be still possible to take an SMTP feed to my own mail server?
I've been running that since the Plusnet double email debacle in 2007
plusnettony
Fixes: 73
Let me clarify that - if you use you're own domain, you should be ok.
On Plus.com, no.
 Tony T
Lorian
Phew. Yes own domain, thanks
Any way I can find out which day I'm being transferred so I can check what's happening?
Also I'll need to find and register my account as supporting a vulnerable person as this email deliveries their chemo and oncology appointments
plusnettony
Fixes: 73
I don't as yet.
When you transfer, you can register as vulnerable on the Greenby portal. I can also make changes our side if you want to PM me.
 Tony T
Lorian
@plusnettony  are you able create a ticket to change IPSTAG on one of my domains for me please?
Fixes: 580
@Lorian
If its registered at 123 then you need to get them to change the IPSTAG.
Note that changing the IPSTAG is only needed to move the registration.
Lorian
It's my 2007 free Plusnet domain registrar is plusnet.
I'm moving my other domains too but I have control over those
Not planning on leaving anything fir greenby
plusnettony
Fixes: 73
Can you PM me the username and domain please? Thanks
 Tony T
Lorian
Sent thanks
