SMTP Authentication
Tykebike
SMTP Authentication
Hello,
Whenever I'm away from home and connected to someone else's wifi I receive emails without any problem but if I try to reply to them or create one then I have problems.
The error message on my Macbook Pro using Mail is:
Cannot send message using the server trutta.f9.co.uk
Verify that you have addressed this message correctly. Check your SMTP server settings in Mail preferences and verify any advanced settings with your system administrator.
The server response was: <[email protected]> recipient rejected - relay denied
Select a different outgoing mail server from the list below or click Try Later to leave the message in your Outbox until it can be sent.
My SMPT host name setting is relay.force9.net
Could someone please help me solve this problem once and for all?
17 REPLIES 17
Fixes: 1,662
Re: SMTP Authentication
Thanks for your post @Tykebike
I'm sorry to see you're having issues sending mail while away from home.
Have you setup SMTP Authentication on Mac Mail's preferences to connect using your mailbox username and password?
Tykebike
Thanks for your reply, sorry for the delay I thought that I replied last night but it doesn't seem that the reply was sent.
Here is a screenshot interrogating the error message and I'm sure it's the same athenitcation as when I am at home
DE581596-7CEF-46C4-ADA7-6EB950E26A9C.jpeg~2.jpgDE581596-7CEF-46C4-ADA7-6EB950E26A9C.jpeg~2.jpg
Moderator's note by Mike (Mav): Personal information removed from a public forum.
LaurenB
Fixes: 131
Hiya @Tykebike, thank you for getting back to us.
Where the 'automatically manage connection settings' is currently ticked, if you untick this you'll be able to ensure the authentication method is correctly set.
Feel free to pop over a further screenshot when unticked if you need further help with the settings, I'd just advise to ensure any personal details are blocked out.
 Lauren Barry
Tykebike
Hi Lauren,
Thanks for the guidance but maybe there are some other settings I need to attend to as well because the test message I created did not transmit. The screenshot below may help (excuse the poor redaction techniques as I need to improve my skills on editing on the macbook with a dodgy trackpad!)
RobPN
Fixes: 14
@Tykebike
Have you tried clicking the 'Advanced' tab to see what extra settings are revealed?
Just a thought.
LaurenB
Fixes: 131
Thanks for getting back to us @Tykebike, I'm sorry the issue is ongoing.
As @RobPN has mentioned, can you please click on the advanced settings and again if you provide a screen shot we can check this over for you.
 Lauren Barry
Tykebike
Hello Rob,
This is the advanced tab screenshot:
Fixes: 378
@Tykebike I might be wrong here ( @RobPN  or @LaurenB  will soon tell me), but I don't think the 'Use TLS/SSL' box should be ticked.
Fixes: 1,662
I'd recommend deleting the duplicate servers firstly so you'd just have one and that should be relay.force9.net
Could you next try ticking "insecure authentication"? If there's no other options afterwards although there should be an option to enter an outgoing port number which is either 25 or 587, and the "server settings" tab still shows your username and password, click the OK button and try sending mail again.
If that doesn't work let's try with secure authentication. You'd just change the "insecure authentication" to either "STARTTLS" or SSL/TLS". If you're using STARTTLS you'd use the outgoing port 25 or 587. For SSL/TLS, the port is 465.
For reference I've taken the information from Here.
Let me know how it goes. Smiley
@jab1
We added SSL to our email system long ago. Keep up at the back there. Wink
Tykebike
Hello everyone,
Here are some screenshots with my interpretation of Gandalf's suggestions, so far I haven't had any success.
Screenshot 2021-10-16 at 10.30.42.pngScreenshot 2021-10-16 at 10.30.42.pngScreenshot 2021-10-16 at 10.36.31.pngScreenshot 2021-10-16 at 10.36.31.png
Fixes: 577
One of the last two should work, but In both cases you will need to set authentication as 'password'
Mook
Seasoned Champion
Fixes: 9
Don't know if this will be of any help, but for my plusnet mail account I have the following settings that with the appropriate changes may work.
Fixes: 145
@Tykebike
When you are "off network" you need to add a password to the SMTP settings. I've had to do this on my Android phone.
From the email help pages
SMTP Authentication (only needed if you're sending emails from a non-Plusnet Internet connection)*
* This is only available if you've got an active Plusnet broadband account
Hope this helps
Dan
Tykebike
WoooHooo, after years of having this problem, it is now solved!
Thank you to all concerned and apologies for my ignorance in these matters and also the slow response but I am on holiday so I can't be tied to my laptop all of the time.
