Plusnet emails not arriving in Outlook 2016
- Plusnet emails not arriving in Outlook 2016
25-01-2020 2:25 PM
I have looked at other similar topics but can't find a solution that works for me.
I have all the account set up and the process goes through normally and Outlook says accounts have been successfully set up.
I have also set the root folders to inbox. I have also right clicked on the folder and when I select "IMAP folders" but inbox is not showing on either. If I delete "inbox" in root folder in advanced settings it appears. I have tried this fix and also the outlook repair tool.
Try this
1) right click in the problematic inbox folder inside Outlook
2) go to IMAP folders
3) click the Subscribed tab and then Query
4) a list of folders should appear now so you should have the problematic inbox in this list
5) click the inbox and then select Unsubscribe
6) click OK
7) go to Send/Receive menu and click the Work Offline option
close the Outlook application (previous command is needed in order to avoid Outlook crashing due to the infinite synchronizing status with the problematic inbox)
9) relaunch the Outlook application (if it crashed in previous step, maybe you need to restart the PC before relaunching Outlook)
10) go to Send/Receive menu and unclick the Work Offline option to enable connection to server again (the inbox should still not synchronize until next steps)
11) right click again the problematic inbox that should not be in synchronizing mode anymore and select again the IMAP folders
12) in the All tab, click the Query and you should see the inbox in some unselected mode
13) select the inbox and click Subscribe
14) click OK and click F9 to resynchronize all your folders
15) you should see now the inbox working normally again
Emails are arriving normally on all other devices.
Any advice welcome
Lone
Re: Plusnet emails not arriving in Outlook 2016
25-01-2020 2:39 PM
Just rebooted laptop and emails have arrived so Ok to close this query.
Not sure which fix did the trick.
26-01-2020 3:54 PM
28-01-2020 10:01 AM
There seems to be an oddity in this area. I have multiple email addresses with Plusnet and other providers. In outlook for some of them, if the root folder is not specified the inbox contents are not shown. I have also noticed that setting impacts how the other folders are shown - either as children of inbox or peers of inbox.
I suspect it has something to do with if when first created the mailbox had been ‘touched’ by the round cube webmail application. Some rainy day when I’ve nothing better to do I’ll try to profile the issue!!
