Is Greenby down?
PhilipHeyes
Champion
Fixes: 20
Re: Is Greenby down?
Sunday 9:10am and we are back in business too with our ex-Plusnet <account>.plus.com emails
via MS Outlook using Greenby hosted servers mail.plus.net and relay.force9.net
pvmb
Champion
Fixes: 15
@blairatholl wrote:
I'm so pleased it's working for you pvmb. But it's not working for me.
Try webmail? 😮
redsox9
Fixes: 4
Both Outlook 2019 and Greenby webmail working for me now.
HeadFullOfWool1
Yep, sure, thanks.  But I did check with the Greenby link you gave, just in case.  But as expected, not recognised.
Shouldn't matter now, except for the underlying account "plusdsl.net" address messages, as I've now got everything redirecting to my IONOS Basic Mail and pull them via Thunderbird (though the IONOS config info pages were wrongly giving USA .com server addresses where it should have been .co.uk, except in one place).
PN webmail is clearly still having a problem - while I can now login, it only gives an error in toaster notification at top and my mailbox structure is missing on the left (no bin/junk, etc).
kenm
Sunday 9-50am Still down for me , get to loading page ??????
screenshot nothing there, all folders etc
PhilipHeyes
Champion
Fixes: 20
If your email has migrated maybe try : https://webmail.greenby.com/
abitpedantic
blairatholl
pvmb, are you wilfully misunderstanding? Which part of 'not working for me' do you refuse to understand?
I suggest pvmb, in the politest possible way, that you're misguided in your analysis. Do not inform me that the Greenby site "a bit erratic in terms of operational speed" - for you - when it is currently broken, dead, unresponsive, knackered, passed away - for me. Do not try and gaslight me by asking whether people (i.e. me) have forgotten so quickly.
I shan't react to your strange commentary any more. It's not worth it.
kenm
tried that many times always get Login Failed normaly
kenm
Have also tried the OLD PN log in get exactly the same as greenby error
screenshot posted a few mins ago
chaswinder
@abitpedantic wrote:
Re your post yesterday about moving to Mythic Beasts, see https://community.plus.net/t5/Email/Update-on-Plusnet-email-migration-to-Greenby/m-p/2050576#M61333
@abitpedantic - many thanks!
pvmb
Champion
Fixes: 15
OK. Sounds good to me. (As you seem to have nothing constructive to say)
pvmb
Champion
Fixes: 15
From your downloaded image...
That's interesting. That looks to be the Old Style version of Roundcube UI (like Plusnet webmail). I always use the default, New Style (which also works well on a phone!) when on Greenby. Seems difficult to believe but could the situation depend on which version of Roundcube UI is being used?
jamroom
Another one unable to access my Metronet,email account on Greenby webmail or via Thunderbird. I can log in to webmail, but there's nothing there and I know there should be dozens of emails in the inbox. Good old Greenby!
pvmb
Champion
Fixes: 15
@jamroom
"I can log in to webmail, but there's nothing there and I know there should be dozens of emails in the inbox"
What version of Roundcube UI? 'Old Style' (as Plusnet webmail UI) or 'New Style' (default Greenby Roundcube UI)?
It looks to me as if the issue is user based (i.e. which Plusnet email species they were on) or - less likely? - webmail UI version based. Which shouldn't affect email client software; so user based more likely?
As an aside, I just tried - successfully - logging in via the old Plusnet webmail. Everything looked to be fine, it is now a mirror of my Greenby email setup. Being cautious I didn't try to 'operate' anything, just logged off. Originally I had an ordinary, simple, straightforward Plusnet email account.
